Hello,
My computer suddenly seems to cut off the juice to my monitor, then the monitor will display something to the effect of "Power save mode." I tested it by unplugging the cable from the computer and it does the same thing.
The display on the monitor will return upon restarting the computer.
The computer seems to "last" longer when it has been off for a little while. However, if the computer has been on and does said problem, I then restart and it seems to have the problem even quicker.
I did another test by opening it up then turning it on and I did not have the problem until I shut it, then it immediately failed.
Considering these things, I'm thinking that it is saving itself from overheating. How do I fix this?
Thanks in advance.
System specs:
Dell GX280
Pentium 4
2.8 GHz
3 GB RAM
Nvidia Geforce 9600GT
Thanks in advance.
System specs:
Dell GX280
Pentium 4
2.8 GHz
3 GB RAM
