help its my first build!!!!
im new to this..... im about to build a gaming system before christmas
i was thinking of these two barebone kits... i plan to use the nvidia 260 216 core 896mb
1. M452-6006 E :: MSI K9N SLI-F Socket AM2/AM2+ Barebone Kit - AMD Phenom X4 9850 2.50GHz OEM, 160GB SATA HD, 2GB DDR2 PC6400, ATX Mid-Tower Case, 550 Watt Power Supply (17.5 lbs)
this one is pci express 2.0
http://www.tigerdirect.com/applica [...] 2-6006%20E
2. P450-9112 C :: XFX nForce 630i Socket 775 Barebone Kit - XFX MG-63Mi-7159, Intel Core 2 Quad Q6600 OEM, 2GB Corsair TWINX PC6400, 500GB SATA II, Silver ATX Mid-Tower Case, 450 Watt Power Supply (20.25 lbs)
i know this is pci express 1.0
http://www.tigerdirect.com/applica [...] 0-9112%20C
Please Help as soon as posible thanks
7 answers Last reply
More about help build
  1. Both links are dead, so can't see all of the details, but what is your budget and we can help you better. The nVidia 260 216 core is a good GPU there are other options that might be better, but your on the right track. If we have your budget, we can make sure you get the best system for the budget allowed.
  2. well i was looking to not to spend no more then 800$ i dont need all that other stuff just a good gamin system:)
  3. i still want to use the 260 216... just becouse its a 896mb card i just had a ati his 3850 hd 512 and was not impressed it was a agp but still i was expecting more for that price.... i been using ati so i wanted to give nvidia a try i like there set up and website and all the reviews are top notch on the 260 216 so i would like to stay with it. but like i said its my first build so im open to any advice..... Thanks alot :wahoo:
  4. CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
    Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
    GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770 - or other HD 4850
    Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
    HD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
    MOBO- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
    RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
    PSU- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
    CPU- Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
    Case- Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
    GPU- SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
    Drive- SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
    HD- Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
    MoBo- GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
    RAM- G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
    PSU- CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
    replace the antec 900 with the antec 300 (they ran out at newegg) and this comes out to about $737
    dont be scared of the 4850, it'll do you right
  5. ok thanks i have the dvd drive in this rig i have a hd but i dont think its a sata.... you think that i would be able to run all games out and still to come on high settings with that rig?? thats all i do is use the computer to web and game i work all the time so this is my way or calming down after a long day of work..... oilfield is tough but i enjoy my job so what ya gonna do :sol:
  6. Is this a good system for games or will i have problems setting it up..im really wanting a good fast computer to play all latest games on full settings thanks.
    Nippon Labs 6 ft. HDMI TO HDMI A/V Gold Plated Cable Model HDMI1.3-6 - Retail
    Item #: N82E16812816002
    Return Policy: Standard Return Policy $9.99
    SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
    Item #: N82E16827151171
    Return Policy: Limited 30-Day Return Policy
    Protect Your Investment (expand for options|hide options)
    Service Net Replacement Extended Warranty Plan
    The product will be replaced and shipped directly to you at no charge(more info27-151-171.0.18)
    1 year: $9.99
    2 year: $14.99
    $24.99
    Item #: N82E16811129021
    Return Policy: Limited 30-Day Return Policy -$30.00 Instant
    $139.99
    $109.99
    SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    Item #: N82E16822152100
    The product will be replaced and shipped directly to you at no charge(more info22-152-100.0.18)
    1 year: $14.99
    2 year: $19.99
    $74.99
    ASUS VH222H Black 21.5" 5ms HDMI Widescreen LCD Monitor - Retail
    Item #: N82E16824236053
    Return Policy: LCD Limited Non-Refundable 30-Day Return Policy
    The product will be replaced and shipped directly to you at no charge(more info24-236-053.0.18)
    1 year: $24.99
    2 year: $39.99
    -$20.00 Instant
    $219.99
    $199.99
    EVGA 896-P3-1267-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
    Item #: N82E16814130400
    $289.99
    $259.99
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
    Item #: N82E16817139006
    The product will be replaced and shipped directly to you at no charge(more info17-139-006.0.18)
    1 year: $24.99
    2 year: $39.99
    -$60.00 Instant
    $20.00 Mail-in Rebate $179.99
    $119.99
    SUPER TALENT INTAIN1MCR All-in-one Card Reader - Retail
    Item #: N82E16820609298
    The product will be replaced and shipped directly to you at no charge(more info20-609-298.0.18)
    1 year: $9.99
    2 year: $14.99
    -$1.00 Instant
    $9.99
    $8.99
    Rosewill RCX-TC050 Thermal Grease - Retail
    Item #: N82E16835200040
    Return Policy: Standard Return Policy -$4.00 Instant
    $8.99
    $4.99
    Rosewill RTK-045 45 Piece Premium Computer Tool Kit - Retail
    Item #: N82E16899261003
    Return Policy: Standard Return Policy -$10.00 Instant
    $29.99
    $19.99
    OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2P10664GK - Retail
    Item #: N82E16820227298
    Return Policy: Limited Non-Refundable 30-Day Return Policy -$12.00 Instant
    $30.00 Mail-in Rebate $82.99
    $70.99
    GIGABYTE GA-X48-DS5 LGA 775 Intel X48 ATX Intel Motherboard - Retail
    Item #: N82E16813128332
    The product will be replaced and shipped directly to you at no charge(more info13-128-332.0.18)
    1 year: $32.99
    2 year: $54.99
    $229.99
    Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
    Item #: N82E16819115017
    Return Policy: Processors (CPUs) Return Policy
    The product will be replaced and shipped directly to you at no charge(more info19-115-017.0.18)
    1 year: $24.99
    2 year: $39.99
    $189.99
    Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
    Item #: N82E16832116488
    Return Policy: Software Return Policy $99.99
    ZALMAN 9500A 92mm 2 Ball CPU Cooler - Retail
    Item #: N82E16835118223
  7. Quote:
    +1 for that.
    @OP: Exactly why do you need X48 board? You can't SLI on X48. Get a 4850/4830/4870 if you plan to CrossFire later. Again you don't need 750W unless doing CrossFire. You don't need DDR2 1066 RAM either.
Build Systems Product
