Hey guys. Never put a system together, so here's my attempt at a build.
Please don't hesitate if you have any input/comments/criticism on this. Like I said, I'm not too knowledgeable about all of this stuff. I plan to use this computer for music production and hopefully some gaming, as I've never had a system good enough to play anything better than starcraft with a good fps rate.
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=8024305
The parts list (For those who don't want to go through the wish list):
Case: COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Specs: ATX Mid Tower, ATX/m-atx motherboard compatibility, 5 external 5.25" bays, 1 external 3.5" drive bay, 5 internal 3.5" bays, 7 expansion slots, 3 120mm fans. Dimensions: 20.7" x 8.4" x 19"ASUS P5Q Pro LGA 775 Intel P45
Power Supply: Antec earthwatts EA500 500W ATX12V v2.0 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Specs: Type: ATX12V 2.0, Max power: 500W, 80mm cooling fan, 2 +12V rails, pci-e connectors: 2x6pin, crossfire ready, SLI certified, >80% efficiency, 4 SATA connectors, 2 PCI-E connector
Mobo: ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
Specs: 8-Phase Power Optimize Stable Overclocking CrossFireX (whatever that means), CPU socket: LGA 775, FSB 1600/1333MHz, 4x240pin, memory standard DDR21200, dual channel, 2x pci express 2.0x16 slots, 3 pci express, 2 pci, 1 pata, 8 sata 3gb/s Dimensions 12.0" x 9.6"
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail
Specs: 4gb (2 x 2GB), DDR2 1000 (PC2 8000), 5 cas latency, timing: 5-5-5-15, Voltage: 20
Processor: Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
Specs: CPU socket: LGA775, 3.16GHZ, FSB: 1333MHz, L2 Cache: 6MB, voltage: .5
Hard Drive: Seagate Barracuda 7200.11 ST31000340AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
Specs: 1TB, Sata 3.0gb/s interface, 7200RPM, 32MB cache, avg latency: 4.16ms
DVD: LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
Specs: 2MB cache, lots of write speeds.
Sound: Turtle Beach TBS-3300-01 7.1 Channels 24-bit 96KHz PCI Interface Montego DDL Sound Card - Retail
Specs: 7.1, 96KHz rample rate, 24-bit digital audio, line in, pci interface
CPU Fan/Heatsink: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Specs: 92mm fan, 900-2500RPM, 45CFm airflow, .9sone noise level, 4pin power
Video: GIGABYTE GV-R485ZL-512H Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Specs: Gigabyte brand, PCI Express 2.0x16 interface, ATI chipset, core clock 625MHz, 800 stream processing units, 1920 mhz memory clock, DirectX10.1, openGL2.1, 2 dvi ports, HDTV/Svideo out, 400MHz, max res: 2560x1600, crossfire suporter, RoHS compliant, built in cooler, 6pin power connector, HDCP ready
What I'm most concerned about is the OEM DVD drive and the OEM Hard Drive.. will I need to buy something else to compensate for that? Also, the sound card: Anyone have any better recommendations? I'm into music production. As you can see, I've put some time into this.
