Corsair 620w
Vista 64bit
I have been having like a "brown out" where my G11 keyboard fades out of power... This is what Speedfan and HWmonitor say about my voltages... I am not sure what to trust, or if they all work with Vista 64bit.. etc
The +12volt line is showing at 6-7 volt, yet Speedfan is also showing it at 12v in another box
Need some advice... PSU is not quite 1 yr old....
Thanks
http://i201.photobucket.com/albums/aa129/xringx/votages.jpg
------------------------------ Q6600@3.6(9x400)Lapped Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x2GB G.Skill PI-Black,CM690 w/ 5x140m 3x120m fans,Idle 28c load 42c-Corsair HX620w
Sponsored Links
Lol, with 6-7v the PC wouldn't probably even boot up. The software is usually bad at reporting PSU voltages. To check your voltages accurately use a multi-meter. See:
http://www.devhardware.com/forums/ [...] 75111.html
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
that voltage sounds high. my +12V reading is under 5V...
------------------------------ ECS A780GM-A, Phenom II x3 710, 4GB Corsair @800Mhz, HIS Radeon 4850, Seagate 7200.11 500GB, Auzentech X-Plosion 7.1 Cinema, LiteOn DL-DVD w/Lightscribe, ASUS TA-863, OCZ StealthXStream 500W, Samsung Syncmaster T240, Windows 7 Ultimate x64
Reply to Nik_I
If that were true your PC would not power on.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Do I have a +12v problem????
There are 1144 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
