Overclocking problem (E6300)
Anonymous
CPUs Authority
Overclocking Expert
Hello!
I spent all afternoon trying to understand why the processor did not want to go further, with no success.
So I check with you geeks! ^ ^
Spec:
E6300 (Conroe) 358 * 7 = 2509Mhz (266 * Orignal 7)
Asus P5LD2
2Gb A-Data PC6400 1:1 5-6-6-18-1
Tagan 580w
all the way to 358 FSB everything goes very well. Run all the flips and settings on auto. Stable in Ortho, 3DMark, etc. ...
But as soon as I raise fsb'n to 359 and it loaded the bios it says:
"NO BOOT DEVICE. PLEASE RESTART": confused:
Which I think is weird since it works cleanly on fsb'n 358th
I have tried raising the volts on all parts, tested a couple other random access memories and change the FSB: DRAM.
There is nothing wrong temperature, about 30 on both cores
Really appreciate all the tips and suggestions!
Regards, Pontus
Anonymous
CPUs Authority
Overclocking Expert
Hi, thanks for the tip!
I think it's the motherboard that puts an end for it. But it seems like i can't raise the multiplier neither drop it. Or maybe it's just the bios that need's an update.
The temperature is in celsius so it's normal. Im from sweden and there is celsius the most common way to measure temperature in .
CPUs Master
Overclocking Master
fisshy, the E6300 Conroe has a X7 internal multiplier.
Pontus, if your tempertues under load are only 30 C, you have something wrong.
Remember, you can increase your CPU voltage. Just keep your load temperatures under 70 C and your vcore under1.50 volts.
Ask the community
