Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > SLI Power problem 9800gtx+
Forum Graphic & Displays : Graphics Cards - SLI Power problem 9800gtx+
Okay I have one 9800gtx+, its XFX standard settings. I'm thinking about buying another one. It requires 2 6pin connectors. And my Power supply only supplies me with two, making there no chance for SLI, right or is there a connector that would allow me to do that?
Also does putting your cards in SLI increase the performance by much. Please give me a estimate, using percentage.
Scurvy
------------------------------ Cooler Master CM 690
E8400 @ 3.0GHz
Asus P5N-D
4GB DDR2 Corsair(2gb now)
Sponsored Links
The lack of 6 pin connectors could be an issue, depending on other factors.
1. What is the total 12v rail amperage of your power supply?
2. Do you have any available 4 pin molex connectors? (If so, how many?)
They now make 9800 gtx+'s that only require one 6 pin supplementary power connector. Thus, if you bought one of these, have 2 4 pin molex connectors available on your power supply, and have enough amperage on the 12v rail of the power supply, then you could SLI.
Toms has charts for performance gains...
http://www.tomshardware.com/charts [...] ks,30.html
With the answers to the above questions provided, someone else can give you a definitive yes or no.
Message edited by terr281 on 12-24-2008 at 06:59:25 PM
Reply to terr281
evga.com says you need 30Amps on your +12v rail(s) to run SLI 9800GTX/+
Reply to xxcoop42xx
There are 774 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
