Trying to find the parts
I just bought a CM Sniper case. It has a 200mm x 200mm x 30mm fan for the intake and top exhaust. I need another to mount on the door and either a 12cm or 14cm fan for the bottom intake. They have a wire for the fan power and another for the l.e.d's. I have been to CM's website, frozencpu, the egg, t.d., etc.. googled it 800 times, even asked CM's tech support. Can anyone tell me where I can find them?
3 answers Last reply
More about trying find parts
  1. Here is the CoolerMaster 200mm case fan with blue led's you are looking for:
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_327&products_id=25136&zenid=dd71044422fb56238f2393d6911725da
    They also have them with red led's and without led's.
  2. ok, so i guess the actual dimensions are 20cm x 23cm x 3cm ? Logically it doesnt make sense for them to make a 20 x 20 AND a 20 x 23. Heard! THaNx a Bunch.
  3. The fan housing is not a perfect circle. The fan housing is more of an oval. Two sides had to be trimmed down so the fans could be attached to front and top panels of pc cases.
    The fan housing is actually 230mm x 200mm x30mm
Power Supplies Cases Fan Components
