Hey everyone. I did a bit of reading about water cooling setups, read some threads, some reviews, looked at some pics, etc., and I think I've settled on a system that should cool pretty much my entire rig(less RAM & HDDs).
The parts I'm looking at are all from Koolance, who from what I can tell seem to be one of the more reputable companies available.
The system I want to build is for my current i7-920 / SLI GTX 260 rig, inside a Coolermaster Cosmos S chassis.
I'm looking at a loop like this:
PUMP(RES INCL) > 360-RAD > CPU > NB > SB > GPU1 > GPU2 > PUMP
My motherboard is an EVGA E758-A1 X58 board. Core i7-920. Corsair XMS3-DDR3 1600Mhz (6GB), and 2 EVGA GTX 260 Core 216 GPUs.
Here are the parts for the system:
Again, they're all Koolanc-produced products.
https://www.koolance.com/water-cooling/product_info.php?product_id=280 - Reservoir & Pump
https://www.koolance.com/water-cooling/product_info.php?product_id=815 - 3x120(360) Radiator (High Flow) up to 1000W Dissipation
https://www.koolance.com/water-cooling/product_info.php?product_id=978 - CPU Block
http://www.frozencpu.com/products/8486/ex-blc-560/Bitspower_Black_Freezer_EIX58NS_EVGA_Intel_X58_North_Southbridge_Combo_Block_BP-WBEIX58NS-BK.html?tl=g30c313s858#blank - Made a change here.. Found a 1 piece Bitspower NB/SB block.
https://www.koolance.com/water-cooling/product_info.php?product_id=966 - GPU Block x2
And then for nozzles and fittings, I chose two different types of fittings for best flexibility and routing of the tubing, and barbed nozzles:
https://www.koolance.com/water-cooling/product_info.php?product_id=469 - 1/2" ID (G 1/4 BSP) Nozzles
https://www.koolance.com/water-cooling/product_info.php?product_id=867 - 45 Degree swiveling fittings (6 pairs total)
https://www.koolance.com/water-cooling/product_info.php?product_id=679 - 90 Degree swiveling elbow fitting (2 pairs, for GPU blocks)
Tubing, VRAM heatsinks and Coolant is:
https://www.koolance.com/water-cooling/product_info.php?product_id=764 - Blue UV Reactive (5 feet worth, so I can cut to right lengths)
https://www.koolance.com/water-cooling/product_info.php?product_id=489 - Two bottles of this, for refills and such
https://www.koolance.com/water-cooling/product_info.php?product_id=129 - Couple packages of this for my GPU VRAM and VREGs, etc. I think these might be it.
So, based on that and the way I want to route the system, is there anything I should change? Is 1000W enough heat dissipation for every block, or should I consider cutting out the NB/SB, or go with a dual-loop system? Any suggestions, ideas, recommendations, etc. are greatly welcomed.
Hopefully I've shown that I have done a little bit of research...
