Sign-in / Sign-up
Solved
Parts on the way would like to be as ready as possible.
  • AMD
  • Overclocking
April 12, 2010 3:29:08 AM
Hi, I recently got enough money to finish my purchase for my new build( it's on the truck very slowly making it's way here). I am a little worried about the Mobo having the correct bios ( should I call the manufacturer after I get it to make sure that it has the correct bios(per serial #) before building ?). But anyway if everything goes well and it Posts :p  I would like to OC the CPU and GPU was just wondering if anyone had a similar build and could give me some pointers before I get going. Is this set up going to allow me above 4 on the cpu(stable)?
My build including what I already have:
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz / C3
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
XFX HD-585X-ZAFC Radeon HD 5850
XFX P1-650X-CAG9 650W ATX12V
Antec 900 two
Windows 7 Pro
Hyper 212 +
24" LCD 1920x1080 res
DVD ROM
2x Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb RAID 0?
Keyboard,mouse ect.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Mainly Gaming/video capturing w/Multitasking internet
More about : parts ready
Best solution
April 12, 2010 5:14:31 AM
you're just one excited little cookie :p  you should just wait till the parts come in dude
April 12, 2010 5:18:26 AM
lmao
ya 3 day shipping my ass:p
m
l
a b K Overclocking
April 13, 2010 1:11:09 AM
it mainly depends on the chip some will let you get higher then others. my 940 does not like to go anything over 4.08 due to one of the cores crashing after breaking 4 so if you get lucky you should get 4 with no problem on most decent boards and if your really lucky you might get 4.1 or 4.2 but dont quote me if you cant get there its all on the cpu and board some dont like oc which is sad but it happens
m
l
April 24, 2010 5:17:35 PM
Hey Guys thank you all for the help I got it all together and spent a while tweaking and stressing over overclocking:p  I wanted 4.0 for some reason I had this stamped in my brain. I ended up with a super cool and stable 3.9. I can run it stable at 4.0 but the volts and heat were a little scary it's amazing how just a little jump can require so much. I am very impressed by the 955 it's a beast runs everything I throw at it and more. Once again thank you all for the help this is a great community.
m
l
April 24, 2010 5:19:35 PM
Best answer selected by zerkerdude.
m
l
