Tom's Hardware > Forum > Motherboards & Memory > Asus > HELP!!! 3 week old custom built AND IT just stops working??/
Forum Motherboards & Memory : Asus - HELP!!! 3 week old custom built AND IT just stops working??/
Hi i had just gotten my pc about hmm 3 weeks ago. Everything ran fine until today all of a sudden it just went off and now i cant reboot it period, the motherboard light goes on though, but the other weird thing is i cleared CMOS dissasembled it and reassembled it twice. IT made my saturday a living hell! please if you could get back to me with a solution i would be greatfull. Im running: an apevia case, ASUS M3A78-EM nvidia 280, 3 gigs ddr2 580watt power supply AMD Phenom 11 x4 810. please HELP!!! Oh ya no over clocking done period
Sponsored Links
Did you build it yourself, or buy it from someone? If the latter, this would be a good time to contact them.
Otherwise, please list the part/model numbers of ALL components in your system, including, CPU, power supply, MB, etc. One thing that comes to mind is that perhaps your PS failed, especially if it's not a top-tier brand.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
For what it is worth ???,, I had one of those M3A78-EM mobo's and I took it back I could not get it to install on my WD 320g hdd,, no way Jose,,, it totally trashed the primary partition,and this was after running WD's Diag's and Zeroing the whole hdd took 90plus min,[and it was/is a known good hdd at that] get a better mobo one of the 780's comes to mind,,only one small suggestion can you get it to boot to a floppy,personally I would not waste any time on it just get it replaced ASAP..:)
Reply to dokk2
About a month ago I couldn't boot up either, I was freaking out. I disconnected power supply, cleared cmos. My cpu fan would kick on but only 20% power, and my light would light up too but no activity in the hard drive...
turns out my reset button was stuck in, I discovered it about 1/2 hour later. doubt it's your problem but check it, check to make sure the power connectors to your mobo are evenly secured down, sometimes when we plug those in they look secured but they haven't clicked in yet.
------------------------------ AMD Phenomx4 9850 black edition
Asus M4A78 Pro
Gskill 4gb ram
Sapphire HD 4870 g.card
Reply to kless001
There are 949 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
