This is a continued post from my other thread-
http://www.tomshardware.com/forum/258447-29-liquid-cooling-help-coolant#t1851504
I am just trying to see if anyone here has had any experience in running Just distilled water and a silver coil without any additives?
I think this is the way to go, but my only worry is pump lubrication. I am running a Swiftech MCP655 and I am wondering if it will be ok in the long term using just distilled water? Or is there an additive I should add for that? Do you think stainless steel, brass, copper will cause corrosion or only aluminum will do that? Or am I ok? Not exactly sure about the science of that..
Just found out something really cool. I think I am gonna use distilled water in my system. I just found out that brass, and silver are both antimicrobial. You don't need to use PT in your loop, all you need is a silver kill coil.
http://www.petrastechshop.com/sikibyia.html
I just read about something called the Oligodynamic effect. Very interesting- read.
http://en.wikipedia.org/wiki/Oligodynamic_effect
Bassically, brass and silver kill microbes naturally. So since I chose to go with a Koolance radiator, which uses brass tubes, and copper fins, and since everything else in my system is copper (stainless steel barbs?), then my system shouldn't have a problem with algae or anything growing in my system, and corrosion shouldn't be an issue since I don't have any aluminum in my system. Either way, I decided I am gonna try and run straight distilled water, with a killcoil, or strait 99.99 silver. Anyways, I decided not to go with colored or dyed coolant, as they break down in your system and cause sludge. I'm glad I went with a koolance radiator instead of an aluminum one. While it isn't the coolest solution, the brass lines should help out a lot killing algae.
I read on evga forums that someone used just distilled water and a single killcoil and has been going good for a year straight without any problems. So I think it's the cheapest, purest, way to go.
