Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Nothing on Screen, Graphic card or Motherboard problem?
Forum Homebuilt Systems : General Homebuilt - Nothing on Screen, Graphic card or Motherboard problem?
Okay, just over a year and half a go (July 2007) I built my third computer.
Intel Q6600 2.4
2GB of RAM 1066
ASUS P5K DELUXE
GeForce 8800 GTS 320
All put in the Antec P182SE Silver Mirror Case with a 650 Watts power
I don’t overclock any of it.
I do a dual boot with Windows XP Pro and Vista Ultimate.
I have never had any real problems with the computer. In Windows XP I installed the Asus Temperature monitor so I can see how hot things are getting. Most time at boot up it would be something around 85-90 Degrees F for both the Motherboard and the processor. (Give or take a couple of degrees)
After playing some game, it would jump to around 105-110 Degrees F for the motherboard. I guess I always knew the motherboard would get hot, but never seemed to get to hot? A couple of times in the last week I was playing the new Call of Duty in Vista, and it would just freeze on me, or end up crashing. I assumed this was my graphic card getting to hot? Nothing that would keep it from not booting up.
Then today I turn the computer on. Powers on fine, but nothing shows on the screen. (The screen turns on, but never gets a signal)
I did test the monitor on another computer and it works fine.
After trying different things, I realize I’m not getting any real post, like I can tell its not booting up (not reading of the hard drive) also I don’t get any lights on my Keyboard.
I first assume its my graphic card. The graphic card does have the fan spin and getting power? I took out the graphic card and put it back in. Or it could be my motherboard.
So before I go off buying a Graphic card? Is there anything else I can do to figure out the problem? ??? What problem am I going to have if I go install an ATI graphic card with out uninstall the Nvida drivers?
Please let me know!!!
Thanks
Sponsored Links
If your system is not POSTing (no beeps of ANY kind), that means probably PSU, motherboard, or CPU.
I wrote this a while back:
http://www.tomswiki.com/page/Troub [...] +New+Build
Like the title says, it's oriented at a new build, but it will work for troubleshooting.
Reply to jsc
Thanks,
The link you sent is not working
I'm not sure why?
Reply to tubaloth
- 0 +
I checked and, right now, I am getting a "timed out" message also. Not sure what is going on.
Reply to jsc
So, last night I realized I wasn't getting any Beep at all. Not even one when it posts.
I took out my graphic card, still no beep.
Took out my ram, unhooked the hard drives and DVD drive. (only the CPU was in)
still no beep. Nothing at all.
I assume this means Motherboard. (I guess it could still be Processor?)
I reset the Cmos and same thing.
I ordered the same motherboard again so I wouldn't have to re-do my whole computer.
I hope I'm on the right track.
Reply to tubaloth
Edit: Sorry, posted to wrong thread.
Message edited by shortstuff_mt on 12-03-2008 at 10:26:20 PM
Reply to shortstuff_mt
I had the same problem. I took my comp in for testing and it turns out that my memory was bad, so it would not POST or show any signal.
Reply to Chrono_45
There are 608 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
