LCD Display Problem
Forum Graphic & Displays : Graphics Cards - LCD Display Problem
Hi,
I have bought a new Samsung SyncMaster 2242LNX (or 2243LNX ?) TFT LCD monitor, I have put it on my old ASUS K8V-MX MOBO which has on-board video (VIA K8M800) and Linux uses VIA graphics driver for that.
As long as I work on command-line it works fine but I can't run X. When I run X then whole screen starts to flicker randomly and the quality of X is too poor to look at. I only got quick set-up guide which says 1680x1050 of optimum resolution at 60 Hz, no manual where I can see Vertical and Horizontal refresh rates :( . Now since I don't have any Vertical and Horizontal refresh rates what to put in /etc/X11/xorg.conf , which requires a range to be specified.
What could be wrong ? My old Samsung 17 inches CRT monitor works fine on it.
My MOBO has PCI and AGP8x slots only, so I am getting ATI Radeon X1650 card. I thought on-board VGA card does not support that higher amount of resolution, so buying this card will solve my problem ?
Message edited by arnuld on 12-26-2008 at 05:30:37 AM
Sponsored Links
I have had mb's with similar Via chipsets . The range of resolutions offered doesnt come any where near 1650 x 1050 . Im not sure if its a chipset or driver limitation , but there were no updated unicrap drivers to even run a 1440 x 900 .
I suspect the only option you have is to install a gfx card
Reply to Outlander_04
- 0 +
Bad new for me, there is only one AGP8x based gfx card in the whole computer market, X1650 with 512 MB or RAM and I don't know wheteher it supports 1680x1050 of resolution *specifically*, though the web-site says it supports 4kx4k. I don't know whether it works on Linux or not, Linux is the only OS I use. 2nd, my mobo supports 1.8 volts cards (not 3.3 V).
If the new card does not work then I am blown as buying a new MOBO will make an AGP 8x based card useless, as all new ones have PCI-Express slots , plus new expanses for CPU and RAM too .. ocuh... it hurts ...
Reply to arnuld
- 0 +
x1650 supports 1680x1050
new cards are the lower voltage, the x1650 should work in your system fine as long as linux has drivers for it
i would just get something under 50 bucks since you obviously dont play games and such
http://www.newegg.com/Product/Prod [...] 814131070R
Reply to kamkal
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > LCD Display Problem
There are 1237 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
