Tom's Hardware > Forum > Graphic & Displays > Nvidia > 9600 GT No Signal problem, very odd why
Forum Graphic & Displays : Nvidia - 9600 GT No Signal problem, very odd why
So recently, I installed a 9600 GT in my computer and when I play CS:S or WoW, I sometimes lose monitor signal. My first thought ... odd. My friend recently gave me the card as it worked for him well and he wanted to upgrade to something else. He tells me he's never had the problem and I noticed he was using Vista.
So I plugged my card in, everything worked, downloaded newest drivers... as soon as I run the video stress test on source... Crash. I was thinking what the hell.
I try installing windows Vista and well... It worked, I've never had a No Signal on vista. Unfortunately I only have 1.5 gigs of ram so it's not really preferable for me to play games with Vista so I had to go back to Windows XP Media Center.
Anyone know why? I've tried downgrading to the second newest driver which is 178.24 and it still went no signal. I'm not sure whats going on if anyone would like to clarify. I'm positive my computer isn't overheating or else I would've noticed in speedfan or do I have to continue using vista =\.
DXDIAG
System Information
Time of this report: 12/26/2008, 02:01:13
Machine name: MIKEWINS
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: GT5056
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+, MMX, 3DNow (2 CPUs), ~2.0GHz
Memory: 1534MB RAM
Page File: 473MB used, 2954MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9600 GT
Manufacturer: NVIDIA
Chip type: GeForce 9600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_C8653842&REV_A1
Display Memory: 512.0 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor: SyncMaster 226BW(Digital)
Monitor Max Res: 1680,1050
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7824 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/7/2008 13:33:00, 6058112 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/7/2008 13:33:00, 6133856 bytes
Device Identifier: {D7B71E3E-4562-11CF-6245-6EE800C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0622
SubSys ID: 0xC8653842
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media USB Headphone Set
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\Vid_0d8c&Pid_000c&Rev_0100&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: usbaudio.sys
Driver Version: 5.01.2600.2180 (English)
WHQL Logo'd: n/a
Date and Size: 8/4/2004 01:07:56, 59264 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Realtek AC97 Audio
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: PCI\VEN_10DE&DEV_026B&SUBSYS_0CA8105B&REV_A2
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5900 (English)
WHQL Logo'd: n/a
Date and Size: 9/26/2005 17:07:00, 3644800 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0x0
HW Memory: 0
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
USB Audio Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC221
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G15 Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC222
FF Driver: n/a
Device Name: C-Media USB Headphone Set
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0D8C, 0x000C
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 12:45:37, 59520 bytes
| Driver: usbd.sys, 8/10/2004 13:00:00, 4736 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x046D, 0xC223
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ USB Human Interface Device
| | | Matching Device ID: usb\class_03
| | | Service: HidUsb
| | | Driver: hidusb.sys, 4/13/2008 12:45:28, 10368 bytes
| | | Driver: hidclass.sys, 4/13/2008 12:45:26, 36864 bytes
| | | Driver: hidparse.sys, 4/13/2008 12:45:22, 24960 bytes
| | | Driver: hid.dll, 4/13/2008 18:11:54, 20992 bytes
| | +-+ HID-compliant device
| | | | Matching Device ID: hid_device
| | +-+ HID Keyboard Device
| | | | Matching Device ID: hid_device_system_keyboard
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 4/13/2008 12:39:48, 14592 bytes
| | | | Driver: kbdclass.sys, 4/13/2008 12:39:47, 24576 bytes
+-+ DeathAdder Mouse
| | Vendor/Product ID: 0x1532, 0x0007
| | Matching Device ID: usb\vid_1532&pid_0007
| | Lower Filters: DAdderFltr
| | Service: HidUsb
| | Driver: dadder.sys, 8/2/2007 17:32:26, 22784 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 4/13/2008 12:39:47, 23040 bytes
| | | Driver: mouhid.sys, 8/17/2001 15:48:00, 12160 bytes
Gameport Devices
PS/2 Devices
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/13/2008 18:13:20, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: PCI Soft Data Fax Modem with SmartCP
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 206.2 GB
Total Space: 234.3 GB
File System: NTFS
Model: ST3250823A
Drive: D:
Free Space: 1.2 GB
Total Space: 4.2 GB
File System: FAT32
Model: ST3250823A
Drive: E:
Model: TSSTcorp CD/DVDW TS-H552D
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 12:40:46, 62976 bytes
System Devices
Name: PCI Soft Data Fax Modem with SmartCP
Device ID: PCI\VEN_14F1&DEV_2F20&SUBSYS_200014F1&REV_00\4&DC268A3&0&4080
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.23.0000.0000 (English), 3/17/2005 10:50:32, 705280 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 7.23.0000.0000 (English), 3/17/2005 10:50:36, 221440 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DPV.sys, 7.23.0000.0000 (English), 3/17/2005 10:51:16, 1033600 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0006 (English), 3/17/2004 13:04:14, 13059 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFProf.cty, 3/16/2005 21:29:40, 133221 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0006 (English), 3/17/2004 13:00:32, 86016 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200014F1\HXFSetup.exe, 3.04.0002.0000 (English), 3/18/2005 11:27:32, 569344 bytes
Driver: C:\WINDOWS\system32\hsfci014.dll, 1.00.0000.0014 (English), 2/23/2005 16:02:10, 42858 bytes
Name: NVIDIA GeForce 9600 GT
Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_C8653842&REV_A1\4&13D46659&0&0020
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 6133856 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 6058112 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 163908 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 475136 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 1368064 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 8826880 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 13574144 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11194 (English), 10/7/2008 13:33:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 3989504 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 3444736 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 1257472 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 3764224 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.7824 (English), 10/7/2008 13:33:00, 2686976 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/7/2008 13:33:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 10/7/2008 13:33:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0004.0028 (English), 10/7/2008 13:33:00, 122880 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0004.0028 (English), 10/7/2008 13:33:00, 122880 bytes
Name: nForce Memory Controller
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&02
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_02FD&SUBSYS_00000000&REV_A1\3&2411E6FE&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 12:36:44, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
Name: nForce HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&03
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_02F1&SUBSYS_00000000&REV_A2\3&2411E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_00000000&REV_A2\3&2411E6FE&0&80
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&59
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 12:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 12:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 18:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 12:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 18:11:54, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&58
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 12:45:35, 17152 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_10DE&DEV_026B&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&82
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 02:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 02:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 01:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 01:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 01:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/3/2004 18:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5900 (English), 9/26/2005 17:07:00, 3644800 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0043 (English), 9/26/2005 17:07:00, 90112 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0048 (English), 9/26/2005 17:07:00, 18771968 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 9/26/2005 17:07:00, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0050 (English), 9/26/2005 17:07:00, 10458112 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0004 (English), 9/26/2005 17:07:00, 156672 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_0CA8105B&REV_A1\3&2411E6FE&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.5009 (English), 7/29/2005 19:11:04, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.5009 (English), 7/29/2005 19:10:46, 301312 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.5009 (English), 7/29/2005 19:10:32, 221824 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 7/29/2005 19:09:46, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 7/29/2005 19:09:46, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0029 (English), 7/29/2005 02:25:32, 33280 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_0CA8105B&REV_A1\3&2411E6FE&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 12:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 12:40:30, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/10/2004 13:00:00, 3328 bytes
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_CB8410DE&REV_A1\3&2411E6FE&0&68
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_0CA8105B&REV_A2\3&2411E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0261&SUBSYS_00000000&REV_A2\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 12:36:41, 37248 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_0CA8105B&REV_00\4&DC268A3&0&3080
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 12:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 12:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 12:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 12:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 15:46:40, 6400 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:51 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/10/2004 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/10/2004 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:17 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:17 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:09:20 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:09:19 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:18 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/10/2004 13:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:41 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/10/2004 13:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:02 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 82432 bytes
system.dll: 1.00.3705.6060 English Final Retail 12/25/2008 21:39:47 1179648 bytes
system.dll: 1.01.4322.2407 English Final Retail 12/25/2008 21:08:29 1232896 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:52 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/10/2004 13:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/13/2008 18:11:56 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 18:12:10 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:11:49 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:11:51 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 18:11:52 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:11:56 35328 bytes
mpg2splt.ax: 6.05.2710.2732 English Final Retail 8/5/2005 22:06:50 165376 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:11:59 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:11:53 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:12:03 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:12:03 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:12:03 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:12:03 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 11:21:32 733696 bytes
quartz.dll: 6.05.2600.5596 English Final Retail 5/6/2008 23:12:40 1288192 bytes
strmdll.dll: 4.01.0000.3937 English Final Retail 10/3/2008 04:02:42 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/13/2008 18:12:42 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/13/2008 18:12:42 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/13/2008 18:11:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/13/2008 18:11:55 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/13/2008 18:11:55 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/13/2008 18:11:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/13/2008 18:11:55 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/13/2008 18:12:42 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:12:01 203776 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:08:04 48640 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 12:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 12:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 12:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 12:39:53 4352 bytes
msdvbnp.ax: 6.05.2710.2732 English Final Retail 8/5/2005 23:01:54 58368 bytes
psisdecd.dll: 6.05.2715.3011 English Final Retail 10/9/2006 16:12:14 235008 bytes
psisrndr.ax: 6.05.2715.3011 English Final Retail 10/9/2006 16:12:30 224256 bytes
mpeg2data.ax: 6.05.2710.2732 English Final Retail 8/5/2005 23:01:54 62976 bytes
msvidctl.dll: 6.05.2715.3011 English Final Retail 10/9/2006 16:15:52 1669632 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:42 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:01 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/13/2008 18:12:10 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5596
CyberLink MP3/WAV Wrapper,0x00600000,1,1,P2GMP3Wrap.ax,3.06.0000.0321
WST Renderer,0x00800000,1,1,WSTRenderer.ax,6.05.2710.2732
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
CyberLink AudioCD Filter,0x00600000,0,1,P2GAudioCD.ax,5.00.0000.0912
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5596
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5596
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5596
PIX Photo Story Source Filter,0x00200000,0,1,PIXPSSourceFilter.dll,11.00.0422.0000
WAV Dest,0x00200000,0,0,PIXWavDest.dll,11.00.0422.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.3114
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.2001
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2715.3011
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Microsoft TV Caption Decoder,0x00600000,1,0,MSTVCapn.dll,5.01.2715.3011
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.1223
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5596
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
VBI Codec,0x00600000,1,4,VBICodec.ax,6.05.2710.2732
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2710.2732
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
P2G Audio Decoder,0x00200001,1,1,P2GAud.ax,6.00.0000.1027
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5596
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5596
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink Demux (PDVD6),0x00400000,1,0,cldemuxer.ax,1.00.0000.2905
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,2.00.0000.0821
CyberLink MPEG-2 Splitter,0x00805000,1,2,P2Gm2spliter.ax,2.02.0000.1919
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5596
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2715.3011
Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5596
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5596
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
P2G MPEG Video Encoder,0x00200000,1,1,P2GMpgVEnc.ax,5.00.0000.0806
CyberLink MPEG-1 Splitter,0x00805000,1,2,P2Gm1spliter.ax,2.02.0000.1919
CBVA Filter,0x00200000,1,1,CBVAFilter.dll,5.01.2700.2180
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
CyberLink Video/SP Decoder,0x00602000,2,3,CLVsd.ax,6.00.0001.1921
CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.0705
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.3322
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.2017
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5596
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WST Pager,0x00800000,1,1,WSTPager.ax,6.05.2710.2732
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2710.2732
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2715.3011
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.00.0000.0727
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5596
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5596
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5596
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5596
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5596
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5596
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.2013
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5596
CyberLink LPCM Converter,0x00800000,1,1,P2GLPCMCvrt.ax,1.00.0000.1224
CyberLink MPEG Decoder,0x00600006,2,3,P2GMVD.ax,5.00.0000.0929
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5596
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5596
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5596
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5596
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5596
Audio Capture Sources:
C-Media USB Headphone Set ,0x00200000,0,0,qcap.dll,6.05.2600.5512
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
USB Audio Device,0x00200000,2,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.05.2710.2732
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2710.2732
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2715.3011
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2715.3011
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2715.3011
Audio Renderers:
C-Media USB Headphone Set ,0x00200000,1,0,quartz.dll,6.05.2600.5596
CyberLink Audio Renderer (PDVD6),0x00200000,1,0,cladr.ax,6.00.0000.1817
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: C-Media USB Headphone Set ,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,17,2,,5.03.2600.2180
USB Audio Device,0x00200000,4,2,,5.03.2600.2180
Sponsored Links
There are 1182 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
