Core I7 920 Temp Problem...
I have a core i7 920 with a Zalman 9900 CPU Cooler and I am having some temperature issues right now. When I first built this machine I overclocked it to 3.6GHz using 1.28V. my temperature reading then was around 24-26C idle and 56-64C full load, it was similar to 3Dgameman's review of the cooler. however a nuke-n-pave and bios update later my temperature shot up to 42-48C idle and 68-74C full load. we tried everything... reseating the heatsink/CPU, backflashed the bios to what i originally had... none seems to work. oh and our ambient temp is 22C.... anyone got anything to say to this??????
More about : core 920 temp problem
Conumdrum said:
Gotta be voltages or a bad mount. I dunno. Odd.
thats exactly what my friend said lol, it baffles me since I cant seems to figure out why did it have such a temp jump. 5 degrees or something would be fine could be a bad temp reader but 20 degrees different is something crazy happening....
Not really. This has happend with the old E8xxx CPUs quite a bit. Also, what Temp program? Also, did you clear CMOS?
Download RealTemp and try the Sensor Test.
I just cleared my CMOS, didnt change much. i use RealTemp and Speedfan
Ask the community
