Is there anyway to bypass this so that if my PC gets shut down, i dont have to take the side off and turn it back on via onboard power switch?
My system is fine, but did i perhaps wire the power button switch up wrong because the power button on my case does not turn the system on .....im not sure if i can turn it off with it, i think i can ill check though. But so far when my system is shut down, i have to hit the onboard switch to fire it up.
What did i do wrong or what setting do i need to switch?
Sounds like you wired the pw_switch wrong. If you read the motherboard manual, it will tell you how to plug in the pw_switch, HDD_led, etc. The entire f_pannel should be laid out. I do this myself, usually that the pw_switch is backwards. The buttons on the motherboard itself, are for problems I would guess. Simply double check you wires, that seems like the only problem to me.
------------------------------System 1
PDC E5200|OCZ 4GB DDR2 800MHz|WD 640GB SATA |Seagate 160GB SATA
|Sapphire Radeon HD 4850 512MB|Corsair 650W PSU|GA-EP45-UD3R
Reply to sprucebr1
