Two setups, which one is better for low power consumption
Last response: in Systems
December 3, 2008 5:55:54 AM
I am looking to build a $200ish rig to be on almost 24/7, and only used for data transfers. Here are the two setups I have come up with, I'm asking which one would be the better of the two for keeping on all day everyday, which otherwise would cause a higher rate of my gaming rig to over heat, and so on.
AMD Build
MoBo - JetWay JM26GT4 Micro ATX AMD Motherboard
Item #:N82E16813153120
Case - Rosewill R102-P-BK Black Computer Case
Item #:N82E16811147111
CPU - AMD Sempron 64 3400+ 1.8GHz Socket AM2 62W Single-Core Processor
Item #:N82E16819104006
RAM - WINTEC 2GB (2 x 1GB) 240-Pin DDR2 667 (PC2 5300) Dual Channel Kit Memory
Item #:N82E16820161677
PSU - Athena Power AP-MPS3ATX20 200W Power Supply
Item #:N82E16817104112
DVD-ROM - LITE-ON Black SATA DVD-ROM Drive Model iHDS118-04 - OEM
Item #: N82E16827106276
ATOM Build
Mobo/CPU - Intel BOXD945GCLF Intel Atom processor 230 Intel 945GC Mini ITX Motherboard/CPU Combo - Retail
Item #: N82E16813121342
Case - APEX MI-100 Black / Silver Steel Mini-ITX Tower Computer Case 250W Power Supply - Retail
Item #: N82E16811154084
RAM - Kingston 2GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model KVR667D2N5/2G - Retail
Item #: N82E16820134192
All of these are from newegg, so if you need more info, comment or just check it out from the eggs. I am planning on running either XP Pro SP3 or Ubuntu 8.04.1. If anybody knows whether I should use one or the other OS, that would also be greatly appriciated.
P.S. I already have the sata adapter for the AMD build so i can power my DVD-ROM
December 3, 2008 6:40:30 AM
get the amd, more performance for almost the same idle power consumption.
December 3, 2008 7:03:15 AM
Far more performance, then Ubuntu for the networking and ease of maintenance, or XP if you favour that platform/have "Linux makes me so scared I do a little bit of pee in my underwear"-itis.
December 3, 2008 7:12:11 AM
thank you guys, quick reply, and helped out alot. i believe i am going to go with the AMD Build with Slomo4Sho's Processor.
December 3, 2008 7:47:54 AM
just dont use cheap **** jetway boards...
