Hey,
ok so im an idiot.
i just left my parents place (which is pretty cold, 13C)
and when i got to my place (around 19C)
i changed my thermal paste to artic cooler 5.
i definitely applied it correctly (redid 3 times with the creditcard spread method, dot method, line method...)
and the core temps are still around 42-44 at idle.
they used to be around 38-39 at my parents place.
does ambient temperature make that much of a difference?
incase any of u are second guessing my application method,
first cleaned it off with arctic cleaner 1
then wiped it with arctic cleaner 2 with a lint free cloth
did not touch either heatsink or cpu's surface with hands.
applied the arctic cooler 5 (using 1 of the methods mentioned above)
put the heatsink on top and screwd it down nicely.
and so on...
seeing how the temperature barely changed each time i reapplied it, (1 degree at most) i just stopped trying and decided to post this. thanks!
ok so im an idiot.
and so on...
