External hard drive repair seagate
i have seagate 500gb external drive that droped & the usb connector came out or apart, is it fixable?
1 answer Last reply
More about external hard drive repair seagate
  1. if you have to ask then, i would have to say not by you
    depending on how bad it is someone handy with a soldering iron should be able to fix it, but unless you have a friend that will do it for you that's likely gonna be rather expensive
    assuming you didn't beat it to bad the drive inside should still be good, so you can take it out of the enclosure and either install it in your pc or another external enclosue
External Drive Seagate USB Connector External Hard Drive Storage
