Hi, i've recently decided to upgrade my old pc. Trying to stick with a $500 budget i've thought it would be best to reuse my case, power supply and Hard drives for awhile along with a copy of window xp home. My current goal is to be able to play WoW on high settings with high FPS and hopefully be able to record gameplay.
My case I can't find online anymore and is about 2 years old. Your standard Mid tower case with 2 rear, 1 side and 2 front 120x fans. I also have 2 IDE hard drives.
The power supply is a big question on if it would work alright.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?Sku=ULT33183
PCU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
MoBo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Total price for upgrades came to $489.96
I've chosen the 8400 over the Q6600 after doing some reading on other forums. Basically what it came down to is that the 8400 will allow me to put my "Distance View" up in WoW more because it is based more on CPU then GPU. There is also no way that I would attempt OC'ing until I got the rest of the parts upgraded on this PC.
Lastly if any suggestions can be made to stick to around a $500-550 budget if there are any "must have" parts that I will need to upgrade. Such as maybe I should get a lesser video card or Processor and get a better Hard drive or PS
