Tom's Hardware > Forum > Homebuilt Systems > New System Build > Crazy time problem! Help!
Forum Homebuilt Systems : New System Build - Crazy time problem! Help!
http://secure.newegg.com/WishList/ [...] er=9378552
Put together that build last night, which is plugged directly into my HDTV through HDMI, and installed Vista Home Premium 64 bit. After it gets past the bios, the system clock goes crazy, moving at a rate of about 1 minute per second. This has an effect on everything time based. I have a video of what's happening here:
http://www.youtube.com/watch?v=Vb4R0ZUdouc
I tried to show all my bios settings in the video, but they didnt come out all that well on my crappy camera, so the fun doesn't start until around 2:28. I took some pictures of my bios settings instead:
http://s733.photobucket.com/albums [...] or46/Bios/
Anyone have any idea what might be causing this? I figure it's either a bad piece of hardware, something important I forgot in the building process, or something wrong in my bios settings. I'm almost certain it's not Windows, since it was also happening when the Vista install disk was starting up, before anything was actually installed. Any help would be greatly appreciated. Thanks!
Edit: What in the hell? Text got randomly replaced with escape sequences. Fun times! Hope this fixes it...
Message edited by thalandor46 on 12-05-2008 at 11:59:59 PM
Sponsored Links
Please edit your post to make it readable.
Reply to GhislainG
^ It's not the OP's fault. The Forum has some kind of a bug that puts random characters near the links.
@OP: Try replacing the CMOS battery.
Message edited by Shadow703793 on 12-06-2008 at 12:00:22 AM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Does it do it when you go into the BIOS? Are the date and time correct in the BIOS? A defective CMOS battery shouldn't cause that issue, but if the system loses it's time, Vista might behave like that.
Reply to GhislainG
Time moves as expected in the bios, but it is inconsistent every time I start it up. My guess though is that this is because the time moves forward a significant amount every time Windows starts.
Yeah, just checked. If I turn it off before leaving the bios, the time in the bios is consistent.
Reply to thalandor46
You verified that the clock behaves normally in the BIOS, but if you load Vista and let it run for at least one hour, has the date changed or only the time? When you power off or reboot the PC and then go back in the BIOS, are the date and time still correct?
Reply to GhislainG
I seem to get more confused with the more I find.
If I enter the bios, shut down, and enter the bios again, about a minute passes on the system time. Expected.
If I enter the bios, continue starting Windows, restart, and enter the bios again (about a 5 minute process), system time is ahead about 30-45 minutes. Unexpected.
If I enter the bios, continue starting windows, wait for about an hour, restart, and enter the bios again, system time is ahead about an hour, date has not changed. I didn't keep exact track of time though, so I might do that experiment again to get more accurate data.
Another question from the clueless! I grabbed the latest bios and the update tool...how do I use them to flash?
Oh for the love of...I somehow managed to delete the post I was trying to edit. Let's see if I can remember what went in here.
-Bios update did nothing.
-Someone suggested that I try booting from a LiveCD. I loaded up NimbleX, and it's clock worked just fine. So it could somehow be a Windows problem, even though I get the same type of problems in the setup before anything installs.
-Turns out I can't do the hour test. Windows sits there for a few minutes and then blue screens, which lasts about half a second before it restarts, so I have no idea what it says. I was out of the room the first time I tried it, so I have no idea if that was happening before. Now that I'm actually staring at the thing, I've also noticed that there's more to the clock behavior. In addition to moving at a rate of about 1 minute per second, it's also repeating the same hour over and over again. So the clock will read 7:15 7:16 7:17 6:18 6:19 etc, and repeat that same hour until it blue screens. The start time increments by a few minutes after every restart, probably the amount of time between startups.
Thanks for your help guys! Really hope I can get this figured out.
When Windows is loaded, go to Event Viewer and check what caused the crash. Your problem most likely has to be caused by hardware that's detected by Windows, but not by the LiveCD. I know that it might not make much sense, but can you use a standard LCD monitor instead of your HDTV?
Reply to GhislainG
Control Panel closes as soon as it opens, so I cant get to the event viewer.
Tried switching to an LCD. Nothing different.
I'm about ready to just send the motherboard back and just call it a day -.-
I agree. Just RMA that motherboard.
Reply to GhislainG
Would be nice to know exactly what is happening, but replacing the motherboard is the best thing for you at this point.
Reply to Proximon
There are 596 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
