Can anyone give me some step by step instruction on how to get my ram up to 1066 from 800? Ram is OCZ DDR2 PC2-8500 / 1066MHz / Fatal1ty Edition / 4GB Dual Channel and I've adjusted the voltage but CPUz still says it is at 400mhz. Help plz!
Memory Clock Mode
This item allows you to control the Memory Clock.
Options: Auto (Default) / Manual / Limit (change to)
Memclock Value
This item allows you to set the Memory Clock.
Options: 200MHz (Default) / 266MHz / 333MHz / 400MHz / 533MHz(use this one)
DRAM Timing Mode
This item allows you to choose to manually or automatically regulate the DRAM
Timing.
Options: Auto (Default) / DCT0 / DCT1(for AM2+ CPU) / Both(for AM2+ CPU)
Hello
I really want to buy this motherboard
as you worked?
with the operating system that busy?
I want to be sure and not take risks with my investments.
thanks before hand.
