Tom's Hardware > Forum > Homebuilt Systems > New System Build > Power Supply Problem with new build
hey i made a new build using hp but the highest power suppl they give is 460 w
# Intel(R) Core(TM) 2 Quad processor Q9300 (2.5GHz)
# 4GB DDR2-800MHz dual channel SDRAM (4x1024)
# 1GB NVIDIA GeForce 9800GT, 2 DVI, HDMI adapter
# 750GB 7200 rpm SATA 3Gb/s hard drive
# LAN port on system board (10/100/1000Base-T), no wireless LAN
# LightScribe 16X max. DVD+/-R/RW SuperMulti drive
# 16x max. DVD-ROM
so is the power supply very low cause my build is coming this wed and i am worried that the power supply is less to run nvida 9800 gt and 2 optical drives
should i swap the power supply once it comes??
please help
Sponsored Links
edit:
Get a quality PSU from Corsair, PC Power & Cooling, Antec or OCZ. A quality 450W+ (ie 450VX) is enough to power a single 9800GT.
Message edited by Shadow703793 on 12-07-2008 at 04:02:44 AM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
welll will it run with a 460 w power suplly or should i immediately swap it with a a higher psu is there any tutorials to install cooling???
Reply to tomahawks619
tomahawk you should have at least 650 watt for your rig to be on safe side. Inadequate PSU in the most overlooked potential problem maker in new system builds. I have used both a 750 PSU ($130) and a 860 PSU ($240) both from PC Power & Cooling. I run the about the same options as you do except in the 750PSU rig, I have a 4870VGA and in the 860 Watt a 4870x2. No power problems whatsoever. Eliminate a number of potential problems and dig deeper to have adequate power.
Reply to steelydan
@OP: The #of watts is irrelevant. What matters is the +12 amps and the build quality. Like I said before you can run a 9800GT on a Corsair 450VX. Please post EXACT PSU model.
This is the specs of the power supply
460 w psu
AC Input
* 100 - 127 V/ 200 - 240 V
* 47 - 63 Hz
* 10A 115V, 5A 230V
DC Output
* +3.3V 15A, +5V 13A, +12V1 18A, +12V2 18A, -12V 0.8A, +5VSB 2.0A
It has the enough amps but what is the brand? I recommend yo get a quality PSU from the manufactures I recommended above. My personal favourite is Corsair or PP&C.
There are 936 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
