So I just return home after two weeks of absence, start up my computer and find that all of a sudden my PC will not run Direct3d applications at all. The message(s) I get in the DirectX Diagnostic tool is:
Hardware accelerated Direct3D 9+ is not available because the display driver does not support it. You may be able to get a newer driver from the hardware manufacturer.
To test DirectDraw functionality, click the "Test DirectDraw" button above.
Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
I am running on an EVGA GeForce GTX 260 with driver version 180.48, Windows XP 32 Service pack 3, a core 2 duo 3.0, 4GB ram and Foxcon P45A01 motherboard. My hardware or software has not been modified at all. In fact, my computer has not even been turned on since it was last running fine a couple weeks ago. I can't imagine would could have gone wrong. Any help would be greatly appreciated.
