Sound distortion help plz
I got a Z-5500 and a titanium X-FI retail version and for 2 months everything went well. Now i get random distortions in difrent aplications at diffrent times etc.
Plz if anyone knows anything about this sorta problem help me.
3 answers Last reply
More about sound distortion
    Is it more likely the happen the longer you are using anything that produces sound? If so, it could the be dreaded Creative SCP (Snap, Crackle, Pop) they've been plauged with the 6+ years now...
    Try re-installing drivers, etc.
  2. umm it's common for x-fi to snap crackle pop with SLI enabled. try rolling back driver version until you get one that doesn't do it with SLI enabled or disable SLI.
  3. Hum i got crossfire, dont know if its same as SLI. I have just installed a windows X-Fi controller upgrade, ill ask again same place if it keeps of geting disstorted, thx for help
Sound Cards Components
