Tom's Hardware > Forum > Smartphones & PDAs > Palmtops > IQue 3600 battery change possible?
Forum Smartphones & PDAs : Palmtops - IQue 3600 battery change possible?
Archived from groups: sci.geo.satellite-nav,comp.sys.palmtops (More info?)
My indispensable IQue 3600 battery is now starting to show signs of age
after about a year of daily use (sitting on the charger every night
and in the pocket during the day, e.g. ~360 charge/discharge
cycles(?)). I would guess the battery capacity is now at about 50% of
what it was when new a year ago.
Does anyone know if the battery is replaceable by mere mortals? Or, is
it not possible at all to replace? Is it a 'standard' type that one
could order online?
Any stories from users who have replaced their batteries would be much
appreciated!
TIA
Sponsored Links
That's the problem of buying a internal battery system. You can send it to
Garmin for a battery change. They will enjoy the money made buy it
it may cost them 4 or 5 dollars to replace it but they will charge you
a$100.00.
<perfb@yahoo.com> wrote in message
news:1119896276.421572.127440@g14g2000cwa.googlegroups.com...
: My indispensable IQue 3600 battery is now starting to show signs of age
: after about a year of daily use (sitting on the charger every night
: and in the pocket during the day, e.g. ~360 charge/discharge
: cycles(?)). I would guess the battery capacity is now at about 50% of
: what it was when new a year ago.
: Does anyone know if the battery is replaceable by mere mortals? Or, is
: it not possible at all to replace? Is it a 'standard' type that one
: could order online?
: Any stories from users who have replaced their batteries would be much
: appreciated!
: TIA
Reply to Anonymous
> age after about a year of daily use (sitting on the charger every
> night and in the pocket during the day, e.g. ~360 charge/discharge
> of what it was when new a year ago.
> is it not possible at all to replace? Is it a 'standard' type that
> one could order online?
You can probably replace that yourself, here is a link for a replacement
battery. Note that it comes with instructions and tools (a T-6 screw
driver probably):
http://store.l-f-l.com/cgi-bin/cp- [...] =1A2W423C2
I have bought iPAQ batteries from that place and found them to be good.
That battery is almost exactly like the iPAQ battery.
You have to pull about 4 small screws, open the case with a little
gentle prying, maybe carefully and slowly peel up a cable held down with
double sided tape, break the bond on some double sided tape holding the
battery down, unplug the old battery, plug in the new, and then put it
all back together.
I think 500 cycles is a typical or maybe even optimistically typical
life for those batteries so you are about due for replacement. They
start winding down at the end your's is doing that.
Jack
Jack Erbes in Ellsworth, Maine, USA - jackerbes at adelphia dot net
(also receiving email at jacker at midmaine.com)
p
Reply to Anonymous
Jack Erbes wrote:
<snip>
> You can probably replace that yourself...
P.S.
I just realized, the red "Price includes tools and installation
instructions" line there is a link to the instructions on how to do it.
You can even evaluate your interest in doing it yourself before you buy.
Jack
Reply to Anonymous
This is a good deal you save $70.00 from letting Garmin do it. Bet that
pisses them off.
"Jack Erbes" <jackerbes@adelphia.net> wrote in message
news:vZednXJ_U4DP-F3fRVn-hg@adelphia.com...
: perfb@yahoo.com wrote:
: > My indispensable IQue 3600 battery is now starting to show signs of
: > age after about a year of daily use (sitting on the charger every
: > night and in the pocket during the day, e.g. ~360 charge/discharge
: > cycles(?)). I would guess the battery capacity is now at about 50%
: > of what it was when new a year ago.
: > Does anyone know if the battery is replaceable by mere mortals? Or,
: > is it not possible at all to replace? Is it a 'standard' type that
: > one could order online?
: You can probably replace that yourself, here is a link for a replacement
: battery. Note that it comes with instructions and tools (a T-6 screw
: driver probably):
: http://store.l-f-l.com/cgi-bin/cp- [...] =1A2W423C2
: I have bought iPAQ batteries from that place and found them to be good.
: That battery is almost exactly like the iPAQ battery.
: You have to pull about 4 small screws, open the case with a little
: gentle prying, maybe carefully and slowly peel up a cable held down with
: double sided tape, break the bond on some double sided tape holding the
: battery down, unplug the old battery, plug in the new, and then put it
: all back together.
: I think 500 cycles is a typical or maybe even optimistically typical
: life for those batteries so you are about due for replacement. They
: start winding down at the end your's is doing that.
: Jack
: Jack Erbes in Ellsworth, Maine, USA - jackerbes at adelphia dot net
: (also receiving email at jacker at midmaine.com)
: p
Reply to Anonymous
cool! thanks very much for the link! will let you know how it goes.
Regards
Reply to Anonymous
There are 1109 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
