Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > PC wont start after changing hard disk
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - PC wont start after changing hard disk
my PC cannot start after i change hard disk. no power to the PC. i only change hard disk but it caused everything stop
Sponsored Links
1. Disconnect the power cord, press and hold power swich 4 few seconds.
2. Disconnect the new hd, and double check all connections. Check the PSU switch if you have one.
3. Connect the power cord and try the power switch.
4. If nothing happens, repeat stage one.
5. Disconnect all no essential hardware from the MB and the PSU.
6. Repeat stage three.
7. Next stage depend on your skill lvl, in your case i think it will be better if you will Get it to Computer lab. If you have spare PSU unit you can try it as well.
Reply to arkadi
did you disconnect any cables while changing the hard drive? or the computer turn on but doesnt load windows and it gives you an error?
Reply to Winly
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
