Creating custom cables using braided cover and heatsink problem
Last response: in Systems
December 8, 2008 2:12:13 PM
Hi I want to tidy up some of the cabling inside my new pc. I have seen a few articles online regarding how to use braided cabling tidy and heatsink material.
The problem that I have is that my connectors are moulded to the wires and although I may be able to get the braid over the wires the heatsink material wont go.
I could cable tie the ends down, but not shrink them using the heat shrink.
Or I could get a larger diameter heatshrink and stretch it. But the problem then would be that once heated it may not fit snuggly enough.
What can I do?
Thanks
a b B Homebuilt system
December 11, 2008 10:17:56 PM
Imo, tape the wires with some electrical tape and you are set. Electrical tape is cheap and easy to use not to mention they come in different colors (heck I have even seen pink, and orange electrical tape)
Also re-name the title of this thread to "Heatsrink cabling help" not heat sink.
