Tom's Hardware Forums » PDA » Palmtops » Fix for HotLib/transport monitor problem - Palm Desktop/Mi..
Word :   Username :
Bottom
Author
 Thread : Fix for HotLib/transport monitor problem - Palm Desktop/Mi..
More Information
Archived from groups: comp.sys.palmtops (More info?)
I solved a problem that was vexing me greatly with the help of a french
language forum archive. I have translated the instructions and am
reposting them here for reference purposes. I hope they will help
someone. I would be tickled if anyone who derives benefit could dash
me an email.
They address problems that give errors like
The Application "Transport Monitor" could not be launched due to a
shared library error:
"B<Transport Monitor><Transport Monitor><HotsynLib.PPC><>"
or
The application "Transport Monitor" could not be launched because of a
shared library error: "h<Transport Monitor><Transport
Monitor><HotSyncLib.PPC><__ct_ _16CTransportRelMacFP18OpaqueT
ransportRefUc>"
For me these problems arose after upgrading to Tiger and when using my
zire 71.
I solved the same problem (in 10.4, Tiger) by following the directions
on this site:
<http://forum.palmattitude.org/ index.php?showtopic=18882>
Unfortunately, they are in French, so I will translate. Note that this
method is used when everything is screwy and you need to toally reset
your syncing/palm. It will eliminate all of your preferences iSync, as
well as removing all Palm stuff. You will need to reinstall Palm
Desktop when you're done (as well as Missing Sync, -including serial
number - if applicable.)
1. Use Terminal to kill all Palm Processes:
Open /Applications/Utilities/Termin al
maximize the terminal window
type "ps -aux | grep Palm" and hit return
(note for CL newbies - that isn't an L, it is a pipe, usually
found over the Enter Key. Also, don't type the quotes - they are their
for clarity on this page only.)
You will be given a list of running processes that are related to Palm
software. On the far left, you will see your username followed by
Process ID Numbers (PID's) If you Use missing Sync, you will see
"root" followed by a PID
type "kill -9 ### ### ###"
substituting your PID's for each of the ### (I put extra spaces in for
legibility - you only need one between each pair of PID's)
If you use Missing Sync, you will need to kill that PID with
"sudo kill -9 ###"
followed by your password.
Trash All of the Following:
/Applications/Palm/
/Library/Application Support/Palm Desktop
/Library/Application Support/Palm HotSync
/Library/CFMsupport/Palm Conduit Licrary
/Library/Preferences/com.marks pace.missingsync.palmos.plist
/Users/yourname/Library/Prefer ences/
- com.palm.hotsync.plist
- com.palm.PalmDesktopinstaller. plist
- com.palm.PalmDesktopsetup.plis t
- Palm Desktop Info
- com.apple.isync.plist <---THIS ERASES iSYNC
PREFERENCES
- com.markspace.missingsync.palm os.plist
/Users/yourname/Library/Prefer ences/ByHost/
- com.palm.HS.T.PC.0030656cef6a. plist
- com.palm.HS.T.S.0030656cef6a.p list
- com.palm.HS.T.USB.0030656cef6a .plist
/Users/yourname/Library/Docume ntation/Help/
/Users/yourname/Library/Applic ation Support/Palm HotSync
HotSyncManager Help
(****IMPORTANT The next step erases your user data for Palm Desktop -
Photos, Voice recordings, Palm Calendar, etc. If you use Palm desktop,
you should figure out how to back this stuff up before you continue. I
don't know, because I don't use it.)
/Users/yourname/Documents/Palm /
3. Use spotlight to search for "Palm Hotsync" If any folders show up,
throw them out.
4. Empty the trash while holding down the option key.
5. If you use Missing Sync, run the "Uninstaller Installer" in
/Applications/Missing Sync/ - this will uninstall what's left of
Missing Sync.
6. Restart
7. If you want Palm Desktop, reinstall using the latest version:
<http://www.palmone.com/us/supp ort/macintosh/>
Restart
8. Ditto Missing Sync:
Restart
9. Launch /Applications/Palm/HotSync Manager
10. Create new user.
11. Sync one time.
12. Launch iSync
Devices ->enable palmos syncing
Do what it tells you
13. Launch Missing Sync
double click "iSync Conduit" to enable for this device"
sync with the button on your palm
Hope that helps!
Related Product
rkk
Profile: stranger
More Information
Juneappal's fix works. I've googled this for weeks and it's the only one that works. It's a bit complicated for those not too technically savy, but just follow the directions. THANKS for the fix!!
RKK
Profile: stranger
More Information
This fix works in Leopard. Actually only deleting CFMSupport, emptying trash, rebooting, reinstalling works.
Profile: stranger
More Information
It doesn't work for me. I didn't find some of the Help folders on my machine; I found (and deleted) ~/Library/CFMSupport/HotSync\ Libraries, not the /Library/CFMSupport/Palm\ Conduit\ Library referred to; otherwise I followed the instructions carefully.
I find that (a) the first HotSync to Palm crashes -- reliably -- during the Calendar phase and (b) when I switch to the iSync conduit I sometimes crash, sometimes not but always fail to sync Contacts. It always crashes with iSync if I sync both Calendars and Contacts. It sometimes crashes if I sync one but not the other. Using slow synchronisation seems to make no difference. If I delete an item from my Address Book, I always get 128 'conflicts' which, as far as I can see, are identical between Address Book and Palm.
Because I wondered what a second sync would do, before switching (again) to the iSync conduit, I tried it. It hasn't crashed yet, but it seems to have got stuck (ten minutes) in Calendar.
So: no joy for me. Deleting all those files did help; repairing permissions first also helped (don't panic if you get a process using a lot of space and time even though Disk Utility says only 1 minute to go: it does finish); but still not what I need. :fou:
Wish I'd done an Archive and Install when I switched to Leopard. :pfff:
Google Ads
News
Lenovo intros 17" LCD with adjustable screen
Published on July 22, 2005
Lenovo doesn't just continue IBM's notebook and desktop PC business, but also has begun launching new monitor products. Read more
LCD-monitor OEM prices continue to fall in December
Published on December 02, 2004
LCD-monitor OEM prices are expected to drop this month, with 15- and 17" monitor quotes to drop US$3-5 and 19" monitor prices to fall US$5-10, according to Taiwan-based monitor makers. Read more
Samsung introduces 30" widescreen LCD monitor
Published on October 11, 2006
Samsung Electronics America yesterday introduced SyncMaster 305T, a widescreen, high-resolution 30" LCD monitor. Read more
Demand for LCD desktop monitors surges 26 percent
Published on March 28, 2005
LCDs now represent almost six out of ten sold monitors for the desktop, according to a report released by DisplaySearch. Users bought more than 21.2 million desktop LCDs in the fourth quarter of last year, posting a 26 percent growth over the third quarter of 2004. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
