How much power?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - How much power?
i currently building a new computer and i don't how much power it needed
here my pc spec
http://www.mwave.com.au/newAU/mwav [...] DY3HMF1XXW
i have chosen a 750W power supply because i want crossfire it later on
Sponsored Links
Looks about right to me.
Reply to mi1ez
Yes the 750W will be more than enough.
Reply to abhijith
+1
------------------------------ "He is no fool who gives what he cannot keep to gain what he cannot lose" -- Jim Elliott
Reply to leo2kp
what about a 650 power supply?
Reply to plote_45
You can easily get by with a good 500w PSU with at least 32amps on the 12v rails for that setup.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
A single 4870 video card uses 152 watts and 13 amps at full load.
Two 4870 video cards in CrossFire mode use 295 watts and 25 amps at full load.
Here is a link to a power supply calculator:
http://web.aanet.com.au/SnooP/psucalc.php
Just fill in as many of the blanks as possible. The result will be for the entire system. Please bear in mind that the wattage will be overestimated because there are a lot of low quality power supplies that uninformed consumers insist on buying. As jaguarskx pointed out, an excellent high quality, stable, reliable 500 watt psu with adequate amperage is sufficient for your system.
Message edited by JohnnyLucky on 03-04-2009 at 06:48:34 AM
Reply to JohnnyLucky
I generally recommend PSU sold by Seasonic, Corsair (HX and TX series), and PC Power & Cooling.
Basically Seasonic manufacturers those PSUs (especially those sold under its own brand name).
Reply to jaguarskx
anyway i get another question,should i get 4850x2 or 1GB 4870
Reply to plote_45
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How much power?
There are 1170 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
