My Gigabyte Ep45-UD3P give me LAN problem . I have updated the driver for the LAN. For the past few week its work smoothly. But today its give problem, one LAN cant use but another one can use. Please help me guys.
Can you be more specific about the issues and what type of network you have (100 Mbps, Gigabit, hub or switch)? Are you using DHCP or did you assign static IP addresses? Are both NICs teamed?
No. I'm using LAN bacle to connect to modem to pc.
You get a dynamic IP address from your router/modem or your ISP. If you switch off the modem by accident and lose your connection, you can run the following commands to get a new IP address:
What do you mean? The PC no longer boots from the hard disk or any other device?
Quote :
when I insert the Vista DVD into the computer and restart it, there is no "press any key to boot from the DVD" appear.
Is your Vista DVD bootable? Did you test it in another PC to verify that it boots from it as expected? I've seen that CD/DVD issue before, but it was usually caused by a defective unit, bad media or the CD/DVD unit wasn't selected before the hard disk in the list of bootable devices. Is the DVD listed before the hard disk? If you press F12 at POST and select the DVD, does it boot from it?
If you are sure that you accurately described your problems and that everything is configured properly, then RMA the motherboard.
