Ever since I upgraded my 4*1gb A-Data Vitesta Extreme Edition DDR2-800+ ram
to 4*2gb OCZ Reaper 1066 mhz DDR2 (OCZ2RPR10664GK),
I began having problems of lots of BSOD.
I ran mem-86 3.5 on the rams.
With only one ram on the slot rams check out OK.
But when I run mem-86 with 2 or 4 ram slots loaded the program freezes.
Did you go into BIOS and set the RAM voltage to RAM Mfg. specs? BIOS will default the voltage to 1.8v. DDR28500 requires more voltage than DDR26400. Voltage, speed and timings must be set manually to reach 1066MHz. specifications.
