I tried setting my RAM to spec on my new system and had a "bad overclock". I got a blue error screen and couldn't get into Windows. Can someone help me figure out what went wrong? On "Auto", things were showing up as 8-8-8-20. I changed the voltage and the speed and manually set the first 4 timings to 8-8-8-21, but something went wrong. Did I change something I shouldn't have in the bios?
My build:
CPU: Intel Core i7 920
mobo: ASUS P6T LGA 1366 Intel X58 ATX
VGA: EVGA GeForce GTX 285 1GB 512-bit
Case: COOLER MASTER HAF 932
CPU cooler: XIGMATEK Dark Knight-S1283V 1x 120mm
PSU: CORSAIR CMPSU-750TX 750W
HDD: Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA
HDD2: Seagate
400gb internal drive (SATA) (from my old machine)
Disc: LITE-ON 22X DVD Burner Black SATA Model iHAS122-04 - OEM
OS- Microsoft Windows Vista Home Premium SP1 64-bit
RAM: G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
RAM info:
Speed DDR3 1600 (PC3 12800)
Cas Latency 8
Timing 8-8-8-21
Voltage 1.6V -1.65V
Multi-channel Kit Triple Channel Kit
Features Compatible with Intel Core i7 series CPU for Intel X58 Motherboard
Many thanks in advance!
My build:
HDD2: Seagate
RAM info:
Cas Latency 8
Timing 8-8-8-21
Voltage 1.6V -1.65V
