Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Building a PC - Power Supply Question
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Building a PC - Power Supply Question
I took a look at the Power Supply FAQ, but I'll admit that my brain shut off by the end of part 1. Electricity was never my strong suit. So, if anyone could give me a ballpark as to what kind of power supply specs I should look at, I'd appreciate it.
To start, I'm going to be running an Intel Core 2 Quad Q9650 3.0 GHz LGA 775 Processor.
I'm planning on this card:
http://www.newegg.com/Product/Prod [...] 6814130365
It recommends a minimum of 550 Watts, but I'm planning on buying another and running them with SLI in the future, probably 4 or 5 months down the line.
The case has a 120 mm fan and a 250 mm fan, the larger with LED lights. I'll be using 4 sticks of 2 GB DDR2, planning to upgrade to 4 sticks of 4 when the price drops. I'm using a 16x/48x DVD Burner, and an 18x/48x DVD Rom. I'll also be running 1 SATA 7200 RPM hard drive, and 1 IDE hard drive, which I believe is also 7200 RPM.
I've checked out some power supply calculators, but I'm not sure they're giving me enough information.
If anyone could just ballpark the sort of specs I should be looking for, I'd be really appreciative. I intend to top the necessity by a bit, just to be safe, so an estimate would probably do.
Sponsored Links
I should mention I might add a second 120 mm fan to the case, just to be on the safe side.
Reply to Brianish
You should get a GTX285 instead for around the same price as that card.
A good quality 600W+ PSU with the required PCIe connectors would be sufficient. Corsair TX750, Seasonic M12 700 or Silverstone ST60F or ST60EF would be good choices.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
nvidia's SLI site recommends quite a bit larger. Are they just looking to make money off of it and/or cover themselves by erring deep into the side of caution?
Also, I notice that the 285 here:
http://www.newegg.com/Product/Prod [...] 6814130442
doesn't have a minimum recommended wattage. Is it likely that by upgrading to that I could save myself money on the power source?
Reply to Brianish
An overclocked Q9550 with 2 GTX 280s in SLI would draw about 610w at full load. With 2 GTX285s it would be about 560w. That's with 2x 120mm fans, 1 hard drive, 2 sticks of DDR2 800RAM. I'd go a minimum of 750w especially if you add a couple more HD and some fans, even a 850w wouldn't be excessive.
http://forums.atomicmpc.com.au/index.php?showtopic=264
http://www.tomshardware.com/review [...] 46-14.html
http://www.newegg.com/Product/Prod [...] 6817139006
http://www.newegg.com/Product/Prod [...] 6817139009
Message edited by dirtmountain on 03-04-2009 at 01:39:56 AM
Reply to dirtmountain
I was looking somewhat idly at this one:
http://www.newegg.com/Product/Prod [...] 6817815003
But I know nothing about the brand. Are they any good?
Reply to Brianish
THG had an OCed 9550 with a 4870x2 (close to 2 GTX285) and it only used 530W at the wall, which is ~450W DC. A 600W would have no trouble with that.
HAF 922 | HX750
Reply to theAnimal
I would skip that one.
Do you want modular?
HAF 922 | HX750
Reply to theAnimal
I haven't seen a quality review of that particular PSU, the Xigmatek 500w got an 8.5 rating from www.jonnyguru.com which is pretty good for a group regulated PSU, but i'd personally go with the Corsair.
Personally i'd prefer to run my PSUs at about 60% of their rated load, they get better efficiency, run cooler, run quieter and last longer.
Message edited by dirtmountain on 03-04-2009 at 02:03:50 AM
I'd prefer it for simplicity's sake but the case is big enough that I don't really care. Some extra wires hanging around won't be too much in the way.
Edit - Modular, that is.
Message edited by Brianish on 03-04-2009 at 03:24:56 AM
Reply to Brianish
I recommend the following Corsair 650w PSU (made by Seasonic):
http://www.newegg.com/Product/Prod [...] 6817139005
It's not modular though.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
The 650 actually doesn't have enough cables for 2 of them. I'm thinking the 850 but something a bit odd: I ran it through Corsair's calculator. When I ran my initial (285, non-SLI) setup, it said 520 would suffice. When I added in the SLI card, it boosted up to 1000. Adding one component nearly doubled the recommendation. Anyone know why? (Lacking other evidence, I'm guessing it's to make more money).
Reply to Brianish
There are 1164 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
