Radeon 5700 not recognizing tv as monitor
Hello,
for some reason i cannot use my tv as a monitor. It is not being recognised to extend from windows xp can you help?
1 answer Last reply
More about radeon 5700 recognizing monitor
  1. Have you tried using some of the newer Catalyst 11.5 driver packs? They have a feature to force detection of TVs. Under Catalyst Control Center(CCC) on Desktop Management there is a setting called Advanced Display Settings.
    http://sites.amd.com/us/game/downloads/Pages/radeon_xp-32.aspx
    There is a button that is called force TV detect, also Force Component Video, but only use Component if your using the Yellow RCA cable or it will cause issues ^.^
    however you will need to use a monitor along with your tv in the inital setup or you will be unable to see what is going on. During the setup mark the TV as display 2 and when your ready to finish mark display 2 as Primary so your TV will be primary source and then you may unconnect the monitor . *TV should be marked as main monitor*
Video TV Monitors Radeon Windows XP
