Added a rear exhaust case fan, idle cpu temps up?
Related ressources:
- ForumSystem temperature increases when rear fan is added
- ForumAdded Fans, Temps went up .
- ForumAdded a side fan , temps went up
- ForumCPU Heatsink Fan Blowing Directly onto Case Exhaust Fan
- ForumLian Li V1000 plus II: Rear fan as intake or exhaust ?
- ForumRadiator fans-intake vs exhaust
- ForumOne Fan - Inlet or Exhaust ?
- ForumWhat should be the ratio of intake and exhaust fans?
- ForumCPU Temp at Idle
- ForumIdle Temps for Intel i5 3570K
- ForumLooking for case which has 3 fan infront, rear , side
- ForumCase fan below PSU - intake or exhaust ?
- ForumRear case intake our exhaust
- ForumComp heat and exhaust fan
- ForumSide Fan Intake or Exhaust ?
- ForumIntake or exhaust fan - a test.
- ForumWill adding top exhaust fan interfere with the CPU push/pull method?
- ForumAre there pulsatile pumps?
- ForumSlowly but surely raising I5 750 up to 4Ghz 46c idle
- ForumIs there such thing as a 100 cfm case fan?
- More resources
Read discussions in other Overclocking categories
Add an intake fan to bring fresh cool air into the case as well, either front mounted or side panel, your rear fan will push hot air out, but you need a reasonable supply coming into the case too, I have 16 fans in total, but I may have a problem hehe
