Tom's Hardware > Forum > Homebuilt Systems > New System Build > First Timer Gaming System - Please Help
Forum Homebuilt Systems : New System Build - First Timer Gaming System - Please Help
http://www.newegg.com/Product/Prod [...] 6827136153 (LG 22x DVD/CD RW Light Scribe)
http://www.newegg.com/Product/Prod [...] 6811129042 (Antec 300 Steel Case)
http://www.newegg.com/Product/Prod [...] 6822148274 (Seagate Barracuda 1 TB 7200.11 RPM HD)
http://www.newegg.com/Product/Prod [...] 6814130400 (EVGA 260 Core 216 SC Video Card)
http://www.newegg.com/Product/Prod [...] 6820145184 (Corsair 2x2 GB Memory)
http://www.newegg.com/Product/Prod [...] 6813128359 (Gigabyte EP45 UD3R Motherboard)
http://www.newegg.com/Product/Prod [...] 6819115036 (Intel Core 2 Duo 3.16 Ghz E8500 Wolfdale Processor)
http://www.newegg.com/Product/Prod [...] 6835186134 (Arctic Cooling Freezer 7 Pro 92mm CPU Cooler)
http://us.creative.com/products/pr [...] 7359&nav=1 (Creative X-Fi XtremeGamer Sound Card)
Here's the deal. This is what I have roughly decided on so far. I have been doing as much research as I can with little to no understanding of computers (to start with anyway). If there are any problems with my rig, please inform me.
-I need to know what Power Supply I need or should get.
-Good deals on Mouse and Keyboard.
-Good deal on a good LCD monitor.
-Good deal on a sound system.
So far, my system costs $880. I didn't plan on spending this much, but I want a system that will last me a long while and play the latest games well. I am not very well off in terms of money, so take that into consideration please. Thank you everyone.
EDIT: This computer will be used by 3-5 people (I am building this computer for my little brothers and sisters as well as myself), and they are all gamers or movie watchers... Which is why I have the 1 TB hard drive, if that is overkill still, please tell me. All advice appreciated.
Message edited by JaceX on 12-11-2008 at 04:05:52 AM
Sponsored Links
anything over 500 watts should be good for a power supply
newegg ussually has good deals on monitors
a one terrabyte hard drive is overkill but not really expensive enough to matter, i have every game u could think of installed, plus all the images backed up, plus at least a dozen movies, and i dont use half my 500 gb
Reply to jlannon
I am not very good at interpreting what monitor is good for what. What size and specs should I try to look for in a monitor and sound system? And what brand of power supply should I go for?
EDIT:
-Should I go for a 750TX Corsair or 650TX Corsair PSU?
-I am going with the 22" Acer.
-I might go with a G.Skill 2x2 Pi Black DDR2 800 RAM instead of the Corsair.
-I am getting Windows Home Vista 64 Bit for $100.
My total is now reaching 1300 with shipping costs. I am BEGGING people to help me bring this price down. If you say I don't need certain things, I can take it out. I am thinking about cutting my 1TB in half... Thought?
Message edited by JaceX on 12-11-2008 at 03:44:19 PM
Reply to JaceX
22" acer is a great choice, make sure the responce time is around 5 ms though, higher than 8 and it'll drive u insane
the 650 tx should be fine
the ram is the same thing just a different company
this one's slightly cheaper and also identicle in performance
http://www.newegg.com/Product/Prod [...] 6820227199
cheaper nearly identical motherboard (same chipset)
http://www.newegg.com/Product/Prod [...] 6813131347
i trust asus more anyway
also, the radeon hd 4870 gives the same performance as the gtx 260
http://www.newegg.com/Product/Prod [...] rchInDesc=
Reply to jlannon
and the on board sound on the mobo is more than sufficient
Reply to jlannon
There are 1306 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
