Help me pick parts for $1000 system
Hello,
I am asked to build a $ 1k system. Can you choose the following parts for me? I have my own list, but I would like to get your opinions. I have already decided on monitor and os. So, please only provide the list. I will oc a little bit. The budget is 1000. I live in the US.
Cpu( please pick intel socket 775 based 45nm quadcore)
Ram: (Prefer 8gb)
Motherboard: ( prefer gigabyte motherboard)
Hd:( prefer 1 tb solution)
Gpu: (Prefer ATI 4850 or 4870)
Case:
Powersupply:
Blu-ray drive:
Cpu cooler:
This pc is mainly for photo processing and blu-ray playback. No serious gaming. But, Solidworks application may be run.
I have decided to stick to 775 platform. But, if you can get me nehalem within budget, I am open to that.
Please help me out. Thank you.
11 answers Last reply
More about help pick parts 1000 system
  1. Asus P5Q-se
    Q9300 if you must have 45nm on budget much better deal on Q6600
    WD Black 1tb
    HD4850
    Antec Sonata III (comes with decent PSU)
    Am i close?
  2. Quote:
    Asus P5Q-se
    WD Black 1tb
    HD4850
    Am i close?
    very close. i have q 6600 at 3.3. it is fast, but i do not know about q9300. According to my research , q9300 can get me to 3 without any problems. how does q9300 at 3. perform against q6600 at 3.3?
    Thank you for your reply.
  3. 8gb ram = $150 $850 left
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231151
    bonus of $40 ebay dropped it again!
    good mobo is $100 to 120 p5q pro = $120 $730 left
    photo and video processing no brianer = quad core cheap system no brainer = q6600 at 3.3-3.6ghz
    q6600 = $180 = $550 left
    psu? you need a good one for expansion you can find many on sale for $100 newegg has great combo deals 750w = $450 left
    i guessed first then found this: (note these pus are great in antec 900 or 1200 cases!) http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.144543
    blu-ray dvd = 110 $350 left
    os =vista home premium $240 left
    dvd #2 $210 left
    combo antec 180 - this case is super quiet (i use this case all the time shipd 2 last week)
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.147909
    open box:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299R
  4. well if you're not gaming why get a 4850? save some $ by getting a 4670 and spend the extra on a Q9550 or at the least a Q9400.
  5. Quote:
    He needs a good a graphic card. Thank you. Any other suggestions.
  6. wrong forum.
  7. This topic has been moved from the section CPU-Components to section Homebuilt Systems by Jake_Barnes
  8. This is not like you requested, just an alternative for $165 over budget and no bluray.
    Total $1164
    Cpu: $299 Intel Core i7 920 Nehalem 2.66GHz
    Ram: $ 165 G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple
    Motherboard: $299 ASUS P6T Deluxe LGA 1366
    HDD: $110 Seagate Barracuda 7200.11 1TB
    Gpu: $160 HIS Hightech H485F512P Radeon HD 4850 512MB
    Case: $130 Antec Sonata III
    Powersupply: $0 Antec Sonata III
    Blu-ray drive: NONE
    Personaly i would get a $100 case take the extra 30 bucks, add 40 more and get a C&C cooling silencer power supply.
  9. if you going to get the Q6600 and OC it to 3.3 then you will want to add a good cooler into the mix too. i don't think the CPU would last on stock cooler when doing heavy tasks like playing blu-ray movies
    blu-ray playback is offloaded to the graphics card.
New Build Systems Product
