Can decide which one to go with I'm looking for a 1600 mhz ddr3 for an Asus p6t (maybe delux1 or 2). I've got it down on the corsair side side to TR3X6G1600C8D and Can decide on the OCZ side if I should go with the Platinum or reaper series and on the platinum the got 2 versions (http://www.ocztechnology.com/products/ddr3/platinum_series)
a OCZ3P1600LV6GK and a OCZ3P1600LVA6GK. Can someone please tell me which of these 3 are best?
Only question I have is the price the OCZ3P1600LVA6GK cost about $365 and the OCZ3P1600LV6GK about $98. Do u really think its worth it? Can the 920 really take that kind of OCing?
P.S. The corsairs TR3X6G1600C8D corsair (163.50) are in the middle.
Taking cost into mind do u really thing "Lvas" area really worth it?
I heard that unless u get the i7 Extreme Edition 965 and instead go with a 920 u cant really OC the memory and its a waste of money to go more the 1333 mhz, is that correct?
P.S. Which of the mem speeds is best(most practical/bang for the buck) for the 920 and an asus p6t mobo? Looks to me like its 1600mhz (though u really cant Oc it that much anyways)
Message edited by sebastian869 on 04-21-2009 at 12:07:04 PM
Both are top notch companies. The best in the business. It looks like between the 2 your are looking at the OCZ has better timings. The dominator and reaper are my two personal favorite models. I am running the DDR2 version of these and they are great. If you have the room this ram will give you some OC head room.
http://www.newegg.com/Product/Prod [...] 6820227415
