The setup sounds nice. While you can put those to hard drives in a Raid 0 config just be aware that it does double your failure probability, since if one drive goes so does the whole array
![:D :D]()
. So long as you back up your data it shouldn't be a problem. As for the liquid cooling if you're planing to overclock be aware that the Phenoms don't overclock to well at the moment so you may want to wait until next month when the 45nm versions come out. Just make sure you get a board with a BIOS that supports it and what not ^_^. If you're going to build something right now then I'd say go with the 9750 or 9850BE for now, since the 9950 seems to have gone up in price for the holidays, and get a board that says AM3 ready somewhere so that you'll be ready for the new phenoms. Basically the AM3 versions will be the same silicon as their AM2+ brothers, just in a package with 2 fewer pins
