Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem With My 9600GT
Forum Graphic & Displays : Graphics Cards - Problem With My 9600GT
Hi,
I am new to building computers but have recently been help to build my own but i am having some trouble with my graphics card... Firstly sometimes when i start the computer the fan makes a horrible whining sound which I can stop by stopping the fan by hand and then letting it go again. The second problem is more serious and when i am playing ETQW i lose all display and my monitor displays a "no input". But when i then start up the computer again it displays perfectly fine. Any Help musch appreciated.
Thanks,
Andrew
Sponsored Links
Sounds like the fan on the card may be failing and that when you game, the card overheats. May want to check the warranty on it.
Reply to ohiou_grad_06
Thanks will check it and replace it
Reply to Badley
#1 the card may be low on power
#2 check pcie cable if properly inserted
#3 psu may be insufficient
#4 card must be defective
#5 if you're not doing anything, i mean when its your free time.check the backside of the card and spot if theres a blown out transistor.
#6 call tech support. caution: may irritate you instead of help you.
these are the things that i did when my old 9600gt started acting freaky. luckily it was replaced.
Reply to wh3resmycar
lol thnks but it must have been the card i have replaced it with a 9600GT OC and had no problems
Reply to Badley
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
