Samsung F3 | New build issue
Last response: in Storage
May 31, 2010 12:19:22 AM
Hi guys,
This is my new build here, first build actually.
ASUS M4A87TD Evo AM3 DDR3 ATX AMD 870 SB850 2PCI-E16 PCI-E1 3PCI 6SATA 6GB/S USB3.0 Motherboard
Sapphire 5830
G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600
Samsung Spinpoint F3 HD103SJ 1TB SATA2 7200RPM 32MB Cache 3.5IN Hard Drive OEM (came in a clear packaging with a small manual. Nothing else)
AMD Phenom X3 720 (4th core successfully unlocked by Asus core unlocker)
Asus DVD-RW
I have put everything together but i cannot get the HDD detected. I have RMA'd two drives already and i still can't get the drive to work. Here is a weird thing though, I bought a 250gb seagate 7200.12 drive to test and that was detected just fine. I would really be surprised if all 3 samsung drives were defective. Another odd thing is the noise coming from the drive. When i have the drive connected to my powersupply it spins up just fine but it makes a little bit of noise. However, if the SATA cable is connected it spins up and then gets stuck repeatedly and clicks multiple times and then shuts down.
I have no idea what to do now and am planning on RMAing the drive a 3rd time. Here are the things i've already tried doing.
- Try various SATA inputs (my board only has 6gb/s inputs) and power cables.
- played with the SATA configurations in the BIOS and played around with the boot order.
- tried to mimic the setting just as the auto-detect did for the Seagate drive
- Tried finding the drive in windows 7 setup
Sadly i don't have another system to test the drive on and i'm running fresh out of ideas.
Thanks!
More about : samsung build issue
a b G Storage
May 31, 2010 10:06:35 PM
Well, my bet is that none of the drives where defective, so points to whomever you bought them from for RMA support.
Try updating the BIOS and then look for a setting for SATA that can be set specifically to 3GB/sec. If that setting doesn't already exist.
m
l
May 31, 2010 10:34:42 PM
Chances are the drives are dead when they came. Did you buy from newegg? because i heard they have absolutely dreadful packaging.
A couple weeks ago I got a box (not from newegg) with 4 Samsung Spinpoints wrapped in double layer of huge bubble wrap and in rigid plastic cases and they all worked out of the box.
m
l
May 31, 2010 10:42:46 PM
I'm not sure the issue is my board. The manual says it is backwards compatible with 3gb/s drives and i have another SATA II drive that works and is detected perfectly fine. Also, why would a SATA connection cause a failure to spin up?
m
l
May 31, 2010 10:45:33 PM
The drive came in no packaging and was in a clear plastic case with no padding. However, i purchased the drive form a walk-in store.
m
l
a b G Storage
May 31, 2010 11:06:37 PM
Is there a setting in the BIOS that allows you to specify 3GB/s? Humour me.
m
l
