Custom Water Cooling Advice Please
im planning on getting on making a custom water cooling setup,,,
i live in Australia no Neweggs is not an option(sorry)i will be shopping from www.pccasegear.com
im not sure about what parts to use but i was thinking about these kits
Swiftech H20-220 Apex Ultima XT Liquid Cooling Kit
Thermaltake ProWater 880i Liquid Cooling System
or if any1 else can list me better stuff?
Edit: i forgot the Specs haha
CPU: AMD Phenom II x4 965 @ stock (for now)
GPU: Sapphire Radeon HD 5750
Ram: Kingston 2x2GB 1333mhz
MoBo: GA-MA770T-UD3P
soo....u want custom but you are buying a kit? kind of backwards if u ask me..but w/e
there are alot of different sizes you can use for fittings. usually they will come with a G1/4 thread and the other end is either a barb or compression fitting. the barb end usually comes in 1/4in, 3/8in, or 1/2. i dunno if they use standard or metric in AU but those are the sizes =)
tubing will have markings on them that will tell you the size of the tube. i believe my tubes are 5/8 OD (outer diameter) and 1/2 ID (inner diameter) if you have 1/2in barbed fittings then you want 1/2 ID tubing.
Ask the community
