Any problems?
Forum Homebuilt Systems : New System Build - Any problems?
SAPPHIRE Radeon HD 4850 X2 2GB - $309.99
ZALMAN ZM850-HP 850W Continuous @ 45°C (Maximum Continuous Peak: 1050W) ATX12V V2.2 / EPS12V V2.91 SLI NVIDIA SLI Certified NVIDIA HYBRID-SLI Certified - 9800 GX2 NVIDIA QUAD-SLI Certified - Dual 9 $149.99
Intel Core 2 Quad Q9550 $309.99
DFI LANPARTY DK X38-T2R $149.99
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler $28.99
LITE-ON Combo Black SATA Model DH-52C2S-04 $22.99
Antec Three Hundred Black Steel ATX Mid Tower Computer Case $49.95
Kingston 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)$44.99
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s$64.99
TOTAL=$1132
I have a copy of Vista buisness x64 laying around and an image from my old system on my server of Vista Home x32 and I can easily use a copy of XP pro
My goal is to have a nice system but not spend more than i needed. Around $1000 is how much i'm looking to spend and I'm pretty happy with this spec if there is nothing wrong with it or any the components. The main game I'm looking to play is CS:Source but this system should get me into higher end games. If you guys see anything that doesn't work well with the system or you kno that a part is junk plz tell me. Mainly concerned about the psu and overall dimensions
Sponsored Links
No problems, but some improvements can be made that won't cost anything:
-The Zalmann PSU was not properly reviewed last I checked. Known good units at that price and wattage are Antec TPQ 850 and Hiper M series 880W.
-There in no reason to get an X38 board. A P45 will OC better and have more features. Gigabyte UD3P for instance. See the recent article on the front page about crossfire scaling.
-For the same price you can get G.Skill 800Mhz memory running at 1.8V. A better deal.
Reply to Proximon
I plan to use crossfire in the future thats why I have an X38. And I dont plan on overclocking. The memory is a 1:1 ratio with the fsb. I'm not an expert on that so if anyone has any tips I like to hear them
Reply to Drip50291
The P45 I mentioned is crossfire. That's why I referred you to the TH article.
Reply to Proximon
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Any problems?
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
