Hey can i get some help.
I looked all through the CCC and I can't find any crossfiring enabling.
I went to the ati.amd.com site to find an update but all i got was an error when i loaded my information.
Is the device manager seeing both? Power going to both? Crossfire bridge? It should be under 'Crossfire X , Configure' in the Advanced settings mode...
In any event, your next question is going to be 'how do I know that it's running?' in which case you'll want to install CCC 8.11, right-click on the icon in the taskbar and enable the 'Show CrossFireX Status Icon' option.
------------------------------AMD PhenomII 940 BE/CPNS 9500 - DFI LP DK 790FX - 4*2GB Patriot DDR2 800 - 2 x VisionTek HD3870 - PC P&C Silencer 610 - WD RaptorX - BenQ FP241W - CM Stacker 830 Evo - Razer Mamba & Tarantula - Wacom Intuos 4 Medium
Reply to WhyFi
