Hi,
I'm one of those rare people who had very good luck with an Aquagate S1. For years my CPU usually sat around 31-33 C and ever exceeded 45C. It ran great at fan idle speed since the day I bought it 3 years ago -I just added some of their funky blue coolant every 6 months and went back to gaming, burning DVDs or whatever mindless sort of nonsense I was up to.
Yesterday - in the midst of killing an NPC - my pc shutdown. I rebooted, checked the temp via BIOS and discovered it was through the roof. My temp monitoring software (Thank you Core Temp) had detected the problem and shut it down.
So I have some heat issues.
Watching it this morning I noticed I had a TON of air in the line. I'd topped the fluid a few months ago - NP since.
I topped it again this morning.
Did the usual bumps, taps, tipping my case, restarts etc. to bleed the lines.
I don't have as much air as I did yesterday, but in the past I have had NO air in the line!
And there is still a lot of air in there that just will not go away.
So.
Is this thing coming to the end of it's life?
Anything I've missed?
It's self contained so I don't see how I can clean much.
I've gone over the lines looking for pinhole leak - zip (besides the fluid fluoresces and I've lighting in the case which shows it when I drip some during a refill).
Ditto the clamps are perfect.
Is this just the pump failing and frothing bubbles into it (cavitation)?
I used to work on cars and understand how to bleed things like brake-lines etc and this looks to be the same.
But I can NOT find a leak anywhere.
Dreading having to rip out my mobo to pull those long heat-sink bolts out from the back.
If anyone knows of a practical way to remove this thing without doing that, feel free to chime in.
If this is where we part ways, I'll probably go back to air-cooling.
This was just sort of a fun experiment, but the hoses kinda get in my way when I want to tinker.
(Please Note: I understand that I didn't spend 6 bills to cool my system. If you did, my hat's off to you. Sincerely, I'm glad you have the extra loot to put into your system. Unfortunately I've read more than a few posts on Tom's lately that are less about being helpful and more about telling the person about A.) Their shoddy hardware selection B.) What an amazing rig THEY have. If you feel the urge to post that, keep in mind this forum is about helping people.
