Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > What antec power supply should i get?
Forum CPU & Components : Power Supplies, Cases & Mods What antec power supply should i get?
ok today i found out my dell 4600 doesn't turn on. Every time i press the the power button nothing happens, i checked inside and not even the led light is on. I search around on forums and found out it could be because of power supply failure which my cousin confirmed. So my question is, which antec power supply will work on my dell 4600?
thnx to anyone who replies, i really appreciate it. I'm still kinda of a newb with computers and this is the first time this happen to me. =]
Reply to rei14
Antec earthwatts EA 380...this PSU is more than enuf for ur PC...
Reply to gkay09
You should be okay with the Antec Earthwatts series of psu's.
Reply to JohnnyLucky
- 0 +
so im guessing any antec earthwatt series will work on my computer, like if i wanted to get the 430 one it will work?
Reply to rei14
Yes it should work.
is it a desktop, tower or SFF?
Reply to average joe
- 0 +
ok thnx =]
and joe its a desktop with a tower
Reply to rei14
- 0 +
Yep...those are good choices. Corsair also has a 400w out right now that is $50 after MIR and has free shipping. That's a good price for a solid PSU.
http://www.newegg.com/Product/Prod [...] 6817139008
------------------------------ Antec 900, ASRock Extreme4 Z68, i7 2600K,
16 GB G.SKILL Ripjaws X (4 x 4GB) DDR3 1600, 8800 GTS 512 SLI
Reply to huron
- 0 +
My 2 cents: do you plan on upgrading your PC in the "foreseeable future"? If so, you might want to spend a bit more for a "bigger" PSU (450-550W) so you can reuse it in you next build. Just a thought.
------------------------------ The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.canardpc.com/cache/banner/600609.png
Reply to Zenthar
- 0 +
got it, installed it, and it works and its not that noisy. =] thnx again peeps!
Reply to rei14
There are 1968 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 8 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
