Hi,
I need some help choosing a new Video Card for my old PC. It's an HP d1000y (all specs listed below), that I ordered from Comp. in early 2005. I had always meant to upgrade the Video Card, a 256MB ATI RADEON X600, but never could afford to do so until now. When I went into the market I was hit with so many different kinds of cards, I am lost as to which one will work with my system specs.
I'm fairly good at using a computer, but pretty much an illiterate when it comes to the tech side and how they work.
I am looking to upgrade so that I can run high end photo editing graphics software like Adobe Photoshop Extended CS4 / Flash, a 26-28 inch flat screen monitor, and also play high end games like COD4, Half Life 2, World In Conflict, Crysis smoothly.
I have one PCI-E port for the video card, and 5 regular PCI ports (two are unused).
My power PSU is 400w. I will probably upgrade to 750W.
Also, should I upgrade my CPU? If so, what would work with my motherboard?
Any help would be greatly appreciated, and I thank you very much in advance.
____________________________________
System OS = Windows XP Pro SP3
System Make = HP Pavilion 061
System Model = PU031AV-ABA D1000Y
Purchase Date = 2, 2005
Main Board Make = ASUSTeK Computer INC.
Main Board Model = Puffer2
Main Board Version = 1.xx
Main Board BIOS = American Megatrends Inc. BIOS Date: 01/23/06 20:09:06 Ver: 08.00.10 A M I - 1000623 20060123
You cant change your processor because it doesnt support the Intel Cores (duo,2,quad etc)... as far as i can tell you can get a mid range card and just hope your CPU doesnt bottle neck it though if it does your looking at a new mobo and cpu (if this is so i STRONGLY recommend just starting from the start and build a new comp) well i say get something like a HD4650 and see how that goes... seriously at the moment i just recommend putting in extra and start a new comp...
