I have a WD 500gb Black ed. sata HD that was recently part of a RAID array that was working just fine. I decided to take the RAID apart and just use the HDs seperately.
One of the HDs that was in the array is now working perfectly. The other now has a strange issue.
If I boot windows 7 up (which is installed on a different HD) with the HD connected, windows can see, format, and use the drive. The problem happens when I try to install windows on it. The windows setup seems completely unable to detect the drive. It detects other drives if I plug them into the same sata port. If I try to install Ubuntu it does the same thing. No matter what I try, I can't seem to get any operating system to detect this drive during the installation process, they can only see if I boot into the OS from a different HD. I have run both a WD and Seatools diagnostic test on this drive and they find nothing wrong. I am currently doing a full (not quick) format in windows to see if that helps.
Anyone have any ideas as to how to get windows/ubuntu installation processes to see this drive?
