G
Guest
Guest
I have a very strange problem at windows xp home edition.The computer is runing properly the first cd,but if i take out the first cd and put another cd inside the cd-rom, the computer is freezing and i cannot do anything.The only think i can do is to press the reset button and restart the compruter.
I must add here that it does not matter if the disc i am using is CD or DVD.
It is not a problem from the cd-rom because recently i changed it.I was using a LG DVD writer and now I'm using a NEC-OPTIARC.
The funny think is that i never had this problem at the xp proffesional edition neither with the LG drive nor with the NEC-OPTIARC drive.
Both editions have been installed from original discs.
